AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 3D 2010 and databases
6 REPLIES 6
smvest
421 Views, 6 Replies
I recenlty installed AutoCAD Map 3D 2010 64-bit on Windows 7. I am using the SQL Server Spatial Connection in CAD to connect to the database. I get as far as connecting to the database but cannot see anything in it. Any thoughts, suggestions would be appreciated.
6 REPLIES 6
in reply to: smvest
Do you have a data store created in the SQL Server ?
Murph
http://map3d.wordpress.com/
"smvest" wrote in message news:6286539@discussion.autodesk.com...
smvest
in reply to: smvest
Murph -
Since I am a database illiterate, could you explain that to me.
Sue
smvest
in reply to: smvest
Yes - there is an existing data store. I can connect to it but nothing shows up in "Data Connect" dialogue box under "Add Data to Map". The Schema list is empty. Sorry about that -
in reply to: smvest
And it worked before? I would try creating a new schema in that data store,
connect to a SDF file and bulk copy it the the SQL Spatial server.
Murph
"smvest" wrote in message news:6286597@discussion.autodesk.com...
smvest
in reply to: smvest
The connection to the database worked on my "old" computer - AutoCAD 2010 32-bit Windows XP Professional. I recently upgraded to a new new computer - Windows 7 64-bit. The list in the "Data Connetions by Provider" in the Data Connection dialogue box no longer contains a connection to ArcSDE. I believe what replaced that connection is "Add SQL Server Spatial Connection". What was in the 32-bit AutoCAD 2010 is not in the 64-bit AutoCAD. The database is already setup and maintained by ArcGIS not AutoCAD.
in reply to: smvest
Ok got it now, The ESRI SDE is running on a SQL Server. You still need to
access it with the SDE connections, if you do not have that on the 64 bit
system then I would say there is not FDO Provider for SDE in 64 bit yet.
Looks like it's time to log on to your subscription site and log a request.
Murph
"smvesT" wrote in message news:6286994@discussion.autodesk.com...
AutoCAD.
”Boost
