AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD Map 2015(64 bit) WMS problem
24 REPLIES 24
Message 1 of 25
kajar
4998 Views, 24 Replies
HII having problem with new Map 3d 2015. When i try to create WMS connection, then error occurs: Failed to initialize Fdo connection. Unable to load the FDO Provider library "WMSProvider.dll":(null).
Does anyone have same issue with WMS?
24 REPLIES 24
Message 21 of 25
braudpat
in reply to: Alfred.NESWADBA
Hello
+1 with Alfred
Are you speaking about a Patch/Hotfix/SP1 for ACAD MAP 2015 (which corrects some WMS some problem) ??
I can't believe it ! But why not !?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 22 of 25
kajar
Cant give you a link to download it, It was possible to download through New tab under notification area. There is also  no any update information in Autodesk webpage.
But today I downloaded  english version Map 3d  trial from Autodesk web  and installed it toanother pc(win 7 64 bit) and WMS worked fine , it seems that Autodesk have already changed installer.
So its recommended  to download new version and install it.
Message 23 of 25
I was able to get my SP1 from the "Autodesk Application Manager" which was an icon on my task bar.  I first had to run an update on that software and then the SP1 was available for installation.
Message 24 of 25
Alfred.NESWADBA
Thx, I already tried that, the SP1 for Map3D is not available through that.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 25 of 25
Your link (http://geoservices.brgm.fr/geologie?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities) will not work for me.
I have also Civil 3D 2015 64-bit
Is it possible to release an SP1 for Civil 3D?
The SP1 for Map will not work for Civil 3D
(who is searching for the SP1 for Map: http://knowledge.autodesk.com/support/autocad-map-3d/downloads/caas/downloads/content/autodesk-autoc...
Tags (3)
