AutoCAD Map 3D General Discussion
Member
Goldhound
Message 1 of 6 (448 Views)
AutoCAD MAP AND ACCESS DATABASE
448 Views, 5 Replies
12-14-2012 12:42 PM
Question?
  Is it possible and if so how...
  If i connect to an Access Database and link to the blocks in my drawing, Can i have the drawing only show the blocks that i have quried in my database or does it just highlight the data in the database?
Active Contributor
bandit1965
Message 2 of 6 (442 Views)
Re: AutoCAD MAP AND ACCESS DATABASE
12-14-2012 02:00 PM in reply to: Goldhound
I use an Access Database. I can query only those objects asked for into a drawing or I can highlight those entries in the database by selecting the centroid or block in my base drawing. So the short answer is yes, if I am reading your question right.
Member
Goldhound
Message 3 of 6 (415 Views)
12-17-2012 12:34 PM in reply to: Goldhound
Thanks, I know i can highlight the records but i am not sure how to display on the map only the blocks that i queried.
Example, I have 200+ thousand blocks plotted on my map and each one represents a seperate item. I have all blocks linked to my Access Database..
  Say i query only the blocks that represent a blue item and say there are 25 blocks that equal this. Out of the 200+ Thousand blocks in my drawing.. all that is displayed on the screen is what is in my query, the 25 blue blocks...
  This is what i want to be able to do...
any ideas?
Active Contributor
bandit1965
Message 4 of 6 (409 Views)
12-17-2012 01:43 PM in reply to: Goldhound
Yes, if the data in the Access database has that detail in one of the fields. You can load the topology for that drawing and execute your query based on the data you want shown.
Murph
Message 5 of 6 (403 Views)
12-17-2012 04:40 PM in reply to: Goldhound
Create a new Map from the display manager, Add data based on a query.
Murph
Supportting the troops daily.
Member
Goldhound
Message 6 of 6 (378 Views)
12-22-2012 07:44 PM in reply to: Goldhound
Thanks!!!
Sometimes you cant see the forest for the trees.....
You are not logged in.
Ask the Community
