AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
AutoCAD 2014 Crash after Rename
5 REPLIES 5
GISAutoCadMap
409 Views, 5 Replies
Hi everyone,
My Application is migrating  from autocad 2011 to autocad 2014.Once i rename the drawing.It throwing fatal error and  crash again and  again.Is there any hot fix for Rename crash issues.Please provide me some   solution.So i am thank ful to all.
GISAutoCADMap
5 REPLIES 5
nestly2
in reply to: GISAutoCadMap
Can you give a little more detail about your system/setup and what you are using to rename the files?  (ie Save Dialog box, Save_As, Windows Explorer, etc)
Here's a similar topic where the problem seems to be related to 3rd party software that integrates with Windows Explorer.
pendean
May I ask why you are seeting help in a forum called THE BREAK ROOM (NON-TECHNICAL DISCUSSIONS)???
Is your issue not important? Is it not a priority to resolve? Do let us know, or ask the admin to move your post to the correct AutoCAD forum you need. Thanks.
GISAutoCadMap
in reply to: pendean
thanks dean,please move this correct discussion room.
GISAutoCadMap
in reply to: nestly2
My OS win7 sp1/32 bit,Oracle 11.2.01,FME2012,VS2010.Some time after rename crash will happened.Some while closing the Record/print was crashed.Please provide me some solution approach.See the screen shot of attachments.
GISAutoCadMap
can you give us details about your "renaming"?
The screenshot you showed in the word-file with the caption "rename record" is not known to me, what command starts that procedure?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
