AutoCAD Map 3D General Discussion
New Member
20090927
Message 1 of 3 (211 Views)
Attribute Domain
211 Views, 2 Replies
07-31-2009 08:30 AM
I am utilizing the ESRI ArcGIS for AutoCAD plugin to edit feature attributes in AutoCAD Map 3D 2009.
Is there a way to control/restrict available attribute values, similar to a Domain in an ArcGIS Geodatabase?
The .dwg I'm editing was created from a personal Geodatabase by using the 'Export to CAD' tool in ArcGIS 9.3.1 basesd on SDSFIE schema, so maintaining consistent attribute values is imperative.
Thanks for any and all help.
Valued Mentor
jackie.ng
Message 2 of 3 (211 Views)
Re: Attribute Domain
08-02-2009 11:51 PM in reply to: 20090927
FDO supports list and range value constraints. But there are two things to note:
1) There's no FDO provider for ArcGIS, however there is FDO providers for ArcSDE and SHP files.
2) List and Range value constraint support varies from provider to provider.
- Jackie
New Member
gingerrc4
Message 3 of 3 (84 Views)
12-26-2013 11:12 AM in reply to: 20090927
I noticed this was an old thread and I thought I would check in and see if anything has changed.  I too am using ArcGIS for AutoCAD to connect to a feature service running on ArcGIS Server.  The feature service is actually a feature class in an enterprise geodatabase.  It would be nice to edit the attributes for the feature service from Map 3d (2012, 2014) and still have access to the geodatabase domains.  Is this possible with some customization on the AutoCAD side?
Robyn
You are not logged in.
Ask the Community
