AutoCAD Map 3D General Discussion
teflon
Message 1 of 8 (245 Views)
Attribut Rotation
245 Views, 7 Replies
11-07-2013 12:51 AM
Using Enhanced Attribute Editor one can set attribute text rotation to 0 when the block is rotated. But it must be done for each block individually. Is there a way to do this for several blocks at the same time or globally?
I know making block or text annotativ does it but it requires redefining block, something I do not want to do.
antoniovinci
Message 2 of 8 (227 Views)
Re: Attribut Rotation
11-07-2013 03:06 AM in reply to: teflon
You should only select those rotated blocks, then _PROPERTIES, and set 0 as "common" rotation angle, sir.
teflon
Message 3 of 8 (221 Views)
Re: Attribute Rotation
11-07-2013 03:28 AM in reply to: antoniovinci
What I mean is a way to change rotation for attribute globally regardless rotation of the blocks.
Blocks are rotated differently but the attributes should stay at rotation 0 or to be able to be set to 0 afterwards.
Murph
Message 4 of 8 (213 Views)
11-07-2013 04:18 AM in reply to: teflon
Dynamic blocks will do that, however you can not use them for point styles and get it to work. One way is to turn off the attributes display then create labels set those to 0 rotations.
Murph
Supportting the troops daily.
antoniovinci
Message 5 of 8 (203 Views)
11-07-2013 05:35 AM in reply to: teflon
I gotcha, sir.
Of course, Murph's "dynamic" advice is very elegant, but let me give you an "old-school" one.
You could select and save only the rotated blocks thru the _DXFOUT command (beware, Ascii format NOT binary), then in Notepad (or better text editor) you can search and replace the angle items, save and open back this modified DXF in Autocad.
teflon
Message 6 of 8 (190 Views)
11-07-2013 08:04 AM in reply to: antoniovinci
Thanks!
It worked!
But I did not find different formats of DXF.
I had already tested ATTOUT/ATTIN but it just changes the value of attribute not the rotation.
antoniovinci
Message 7 of 8 (162 Views)
11-07-2013 10:56 PM in reply to: teflon
The DXFOUT suboptions are under the Tools menu:
teflon
Message 8 of 8 (140 Views)
11-10-2013 01:21 PM in reply to: antoniovinci
And how do I find my blocks? There are lots of stuffs in there!
