AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Assign Global Coordinate System, Select Coordinate System, no list of Codes
1 REPLY 1
JeffEnge
925 Views, 1 Reply
Using AutoCAD Map 3D 2011 and attempting to set the Coordinate System with Assign Global Coordinate System.  The problems are that the Select Coordinate System... button does nothing.  I assume is should load and display a list of codes and coordinate system and then the user select the desired code.  But since no list displays there is no way to see the codes.  I have searched on the forum and found a list of codes but manually entering a code generates the error “Can't save projection for current session.”
Is there some installation issue or some other way to set the Coordinate System (NAD 83 Zone 3N)?
1 REPLY 1
antoniovinci
in reply to: JeffEnge
Did you just apply the last Service Pack?
If it doesn't help, you should uninstall and then reinstall the whole package, sir.
”Boost
