I have defined map annotation text which shows a Lot number and an area. The data is attached to the polyline, and the Lot number is manually entered in via the properties pallete. The area field comes from the area of the polyline. I am struggling to figure out how to get the area shown to 0 decimal places, and also to add a m² suffix to all of the areas.
Can anyone help with this?
Cheers, Patrick
Ok, i have figured out the precision - but can anyone help to add the m² suffix?
Thanks.
If you are using map anno blocks I would use Mtext for M2 (M\u+214A) and right justification for the attribute.
Hi Murph, thanks for the reply. I have defined the template using mapanntext, the first line picks up the Lot number previously defined, and the second line picks up the area of the polyline. I am not sure how to add the area of the polyline as a field to mtext in the block editor as you cannot select the polyline to link it to using that method. I cannot add the m² to the end of that as mtext as it is not linked to the size of the area, so if you have a large area it is over the top of the m².
My mapanntext is (rtos .area), how can i add that as a field into a mtext?
Thanks, Patrick
I have finally figured this out. This is expression value in the mapanntext dialog
(strcat (RTOS .AREA 2 0) "m²")
Thanks for your help everyone.
Patrick
@PatrickManson wrote:I have finally figured this out. This is expression value in the mapanntext dialog
Patrick
I tried that way as well but couldn't get the 2 on the M2 to half size. 🙂
As for the scale of the mtext uae the same size as the attributte then when you insert use scale option and scale based on the area.
Here you have the right Unicode syntax, my dear:
(strcat (RTOS .AREA 2 0) "m\U+00B2")
@antoniovinci wrote:
@Anonymous wrote:
I tried that way as well but couldn't get the 2 on the M2 to half sizeHere you have the right Unicode syntax, my dear:
Thanks sweety.
For the newbies, the full list of Unicode codes is available by means of:
WIN-R => CHARMAP
Hey,
I'm working with your formula, I need to use 2 decimal instead of "no decimals". So what does the 2 0 stand for?
(RTOS .AREA 2 0)
I tried typping (RTOS .AREA 2 2) for 2 decimals, but it didn't work, can you tell me the correcto formula?
Hi Sorry, i cannot even remember where you enter that formula in! i have played around with my template, but cannot see where to do that anymore - if you can help with where you enter the formula i will see what i can do.
cheers
I have also been working on this and successfully edited the formula to produce 3 decimal places.
(strcat (RTOS .AREA 2 3) "m²")
See screen shots.
Hope this helps.
Paul
Your formula is correct (rtos .AREA 2 2)
but you should be careful with DIMZIN variable because RTOS (lisp conversion function) read DIMZIN value to remove (or not) 0 value at the end.
By default DIMZIN is set to 8, so if you have a real value 12.5 and use (rtos 12.5 2 3) you obtain "12.5".
If you want to obtain "12.500" you should set DIMZIN to 0, then rtos convert with good number of decimal even with 0 value.
Olivier
Olivier Eckmann
