AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Arcview SHP files import on MAP 6
3 REPLIES 3
306 Views, 3 Replies
I'm trying to import SHP files (arcview) into map6 and it seems that it does
not recognize any SHP files neither other formats as MIF\MID.
The new import on the Map6 simply ignores the shp files, when i'm browsing
to directories with shp's these directories seems to be empty.
Can someone advise?
Zachi
3 REPLIES 3
The SHX file has to be in the same directory as the SHP File.
Then Map will see the shape file
Marc Valade
CAD/GIS Plan Tech.
Ministry of Transportation, Ontario
www.mto.gov.on.ca
"Zachi Flatto" wrote in message
news:D2DB23EFE0C6AFAB2C23E2189B4B175A@in.WebX.maYIadrTaRb...
> Hi,
does
> Can someone advise?
> Zachi
Zachi hi,
You asked me about this but didnt call back.
There is no problem!!!
Arad
"Marc Valade" wrote in message
news:14568A5098FCF5B47490DF51B83623BF@in.WebX.maYIadrTaRb...
> Marc Valade
> CAD/GIS Plan Tech.
> www.mto.gov.on.ca
> > Hi,
> does
browsing
> > Can someone advise?
> > Zachi
Hello Zachi,
What you are experinecing is related to the Graphic User Interface in Map 6.
In Map 6 you specify a directory from within the Import Location dialog box,
and not the specific Shape files. When a directory is selected, all of the
Shape files in that directory are imported. The next dialog box gives you
the ability to filter the SHP's you want to import into the Map 6 project.
Mark Christian
GIS Product Support
Autodesk, Inc.
"Arad Gazit" wrote in message
news:63C025E950525A9B94688623DA896353@in.WebX.maYIadrTaRb...
> Zachi hi,
> Arad
> > Marc Valade
> > CAD/GIS Plan Tech.
> > www.mto.gov.on.ca
> > > Hi,
it
> > does
> browsing
> > > Can someone advise?
> > > Zachi
”Boost
