AutoCAD Map 3D General
Active Contributor
Message 1 of 6 (316 Views)
Adjustable Bar Scale
316 Views, 5 Replies
05-28-2009 08:48 AM
I work with Autodesk Map 3D and I was wondering if the latter provides a bar scale that will adjust automatically to the size of the plotting paper.
Thanks a million!
Valued Contributor
Message 2 of 6 (316 Views)
Re: Adjustable Bar Scale
05-28-2009 10:34 AM in reply to: Victoria12
Not currently.
I have had to build one useing the Field comand linked to the viewport. The scale itself remains static, but the numbers change.
This is also linked to the scale at the bottom if you are useing A-cad 2008,09,or 10.
Active Contributor
Message 3 of 6 (316 Views)
05-28-2009 10:44 AM in reply to: Victoria12
Thank you so much for replying.
Active Contributor
Message 4 of 6 (316 Views)
05-28-2009 12:07 PM in reply to: Victoria12
I am trying to create an adjustable Bar Scale using the field command, as advised by Soocom1 above.
I chose 1"= #' from the field menu. It gave me the following: 1" = .2154' .
In the field expression box, I got the following:
%<\AcVar.16.2 PlotScale \f "1\" = %lu2%zs12%ct9[0.0833333333333333]'">%
The Edit Scale List is set to 1"=1" where 1' of paper is equal to 0.08333333 drawing feet.
Where does the number 0.2154 come from?
Thanks a million!
Active Contributor
Message 5 of 6 (316 Views)
05-30-2009 09:43 AM in reply to: Victoria12
Help..anybody?
Thanks a million!
Active Contributor
Message 6 of 6 (160 Views)
08-09-2012 08:35 AM in reply to: Victoria12
2013 has a scale bar tool.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
