AutoCAD Map 3D General
indianadarren
Message 1 of 8 (634 Views)
Access file not attaching
634 Views, 7 Replies
02-27-2012 09:02 PM
I am trying to ATTACH this Access file. I'm in the Task Pane, map Explorer tab, selecting the Data Source icon. I have used the right click - attach method, as well as the two other methods of Attaching DATA sources (i.e. drag & drop)...nothing is working. Any ideas? Is the file bad?
Attached for your consideration
haha, just got this error message when I tried attaching it to this post: "The file does not have a valid extension for an attachment.doc,pdf,dwf,dwg,dxf,dst,gz,gzip,zip,bm,bmp,gif,jfif,jpe,jpeg,jpg,psd,tif,tiff,png,htm,html,xml,xls,lsp,svf,3ds,vcf,png,text,txt,log,env,dcl,rvt,rfa,ipt,iam,ipn,dwfx,idw,csv,nwf,nwc,nwd,sdf,cfz,vtfx,vtf are the valid extensions."
If you include your email address I will send it to you for your consideration.
thanks in advance!
*Expert Elite*
Alfred.NESWADBA
Message 2 of 8 (630 Views)
Re: Access file not attaching
02-28-2012 02:45 AM in reply to: indianadarren
You can connect to MS-Access with two ways
  • using command _DBCONNECT
  • using command _MAPCONNECT and try it via ODBC
....and please say you have a 32bit OS, otherwise you have to work with workarounds (as there a no drivers for MDB-files for 64bit except you install >>>this<<< and that may be problematic with some kind of office-installations).
To verify what's now the better method depends on what you like to do with the MDB-data.
You can't "attach" is as reference as the MS-Access database has no graphical objects to be shown on the modelspace.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
indianadarren
Message 3 of 8 (605 Views)
02-29-2012 03:20 PM in reply to: indianadarren
No, not working. I have a map file without data. I have an Access file with data. According to the following url, I should be able to link them and then generate a link template.
http://docs.autodesk.com/MAP/2010/ENU/AutoCAD%20Map%203D%202010%20User%20Documentation/HTML%20Help/i...
also, here:
When I follow the Autodesk "How to Instructions" the results are attached as a jpg. Epic failure, but only @ work - this works fine on my home computer (piece of crap laptop). Are the problems linking Access data to map files?
indianadarren
Message 4 of 8 (602 Views)
02-29-2012 03:28 PM in reply to: Alfred.NESWADBA
RDBMS:[Microsoft][ODBC Driver Manager] The specified DSN contains an architecture mismatch between the Driver and the Application.
This is the specific error
hope it helps
*Expert Elite*
Alfred.NESWADBA
Message 5 of 8 (585 Views)
03-02-2012 02:05 AM in reply to: indianadarren
and the main question once more: you are working on 32bit or 64bit?
- alfred -
Alfred NESWADBA
Valued Mentor
Ajilal.Vijayan
Message 6 of 8 (540 Views)
04-05-2012 06:44 AM in reply to: indianadarren
Hai,
I am working on 64bit , windows 7 and using Civil 3d 2012.
I am also getting the same message while I trying to connect to access or Excel.
Pleae have a look at the images attached.
Active Contributor
Message 7 of 8 (533 Views)
04-05-2012 08:03 AM in reply to: indianadarren
If you are running Windows 7 (64-bit) with AutoCAD 64-bit you can't connect to 32-bit Microsoft Access/Excel without significant workarounds.  Search this forum for the workarounds.  The easiest workaround is to install a 64-bit version of MS Office.  Otherwise you have to uninsall 32-bit MS Office, download a MS Access driver 64-bit from Microsoft and then reinstall the 32-bit MS Office.  This information is based on my recollection from reading similar posts on this subject.
Valued Mentor
Ajilal.Vijayan
Message 8 of 8 (496 Views)
04-08-2012 11:21 AM in reply to: indianadarren
Hai,
Thanks for your reply and forgive me for my late reply.
Yeah now I have to deal with our IT team and let see what happens!!
At the same time I have done some workaround and I found this article saying that you can use The 32-bit version of the ODBC Administrator tool on 64-bit platform.
But again I need the IT team to solve it.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
