AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
64 bit access database driver
5 REPLIES 5
1111 Views, 5 Replies
Microsoft has come out with the 64 bit access db driver.  Has anyone had any success making a connection in Map 3D 2011.  I've tried but with no success.  Murph can you help?
http://www.microsoft.com/downloads/details.aspx?familyid=C06B8369-60DD-4B64-A44B-84B371EDE16D&displa...
AccessDatabaseEngine_X64.exe
5 REPLIES 5
Murph_Map
Either Jackies Blog as he replyied or this one http://through-the-interface.typepad.com/through_the_interface/2010/04/64-bit-driver-for-microsoft-a...
When I had a 64x machince I had the beta drivers but due to work load and having to reinstall the MS Office 2007 suite to use them I didn't try it out.
Murph
Supporting the troops daily.
ezfisher
in reply to: Murph_Map
I took the connect string that was posted and edited my udl using notepad to reflect that string and got the database to connect
Murph_Map
Here's another link on setting it up that links to a video.
http://gisexchange.typepad.com/blog/2010/08/odbc-on-x64-operating-systems.html
Murph
Got it!  Thanks to you all.
”Boost
