Thank you very much to everybody!
It works!
Each one of you gave me an input to get the target and I did it without
scripts.
This is what I did:
I exported x,y,z and block attributes (TREE HEIGHT and TREE NAME.....so I
can query them) in txt format. I converted it in shp format in Arcview. I
drapped it on the DEM and exported in 3D shape file.
I re-imported the 3D shape file in Map specifying a block (thanks
Warren...this was the missing piece!) and the object data table.
Now I've got what I needed:
blocks in the correct x,y,z position with all the object datas associated.
Now I can query them and substitute different type of trees'3Dblock in
function of TREE HEIGHT and TREE NAME.
Thanks again to everybody!
Paolo
"Jim Claypool"
ha scritto nel messaggio
news:4BC5EC759EA3D687B02A0FEE2BBC58CD@in.WebX.maYIadrTaRb...
> Are the x and y coordinates of the block and the corresponding point
exactly
> the same?
YES, x,y coord are the same.
I did it in this way: I exported them in shp format,
> If so this should be a fairly simple lisp routine to find the correct
point
> and move the block.
> "Paolo" wrote in message
> news:49FF4BCCB64F7D97D6910EB8214E67F5@in.WebX.maYIadrTaRb...
> > Is it possible to place a BLOCK in the xyz coord of a POINT?
> > Which is the correct query?
> > This is my problem:
> > I've got to Z place a lot of blocks representing trees. Their elevation
is
> > zero, now.
> > Above these blocks I've got points placed in the correct Z position
(where
> > the blocks must placed).
> > How can I do?
> > I tried a lot of queries but without results.
> > I'm thinking to create a buffer around the points, intersect the points
> with
> > the buffer and catch the elevation object data, create a plygonal
topology
> > with the blocks....
> > I think there's a shortest way using Map.
> > Thanks in advance
> > Paolo
