• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Map 3D Developer
    geokh
    modified date
    141 Views, 3 Replies
    08-04-2012 01:30 AM
    Greetings, i would like to ask u this....
    Iam using AutoCAD map 3D and i want to find out how to add modified date, or creation date to quick properties or properties? So I can see when this layer or this 3dpolyline was created and if i can see also by whom it was created...
    The summary i want to add modified field to each layer i make, so when i modified it i can see when it was modified or created and by which user
    Please use plain text.
    Re: modified date
    08-05-2012 10:33 PM in reply to: geokh
    >>>crossposting<<<
    You first need to write an app that watches creation and modifications of objects and save that date/time to the entities. If you have done these part of the work you can look for how to display this data in property-window.
    Depending on what development-type you are using (ObjectARX, dotNET, LISP, ...) >>>this link<<< may be a help for how to get additional info displayed with the property window.
    - alfred -
    Alfred NESWADBA
    geokh
    Re: modified date
    08-05-2012 10:44 PM in reply to: geokh
    Thx alfred, for ur help :smileyhappy: , my friend is there a way to use thirdparty application that can help me do this or an ready lisp that i can use , i will look at the link u gave me , but for now is there a fast solution ?
    Re: modified date
    08-06-2012 02:13 AM in reply to: geokh
    Sorry, I don't know any application that is storing modificationdate and creationdate on each entity.
    And I think there are things to verify how you need it, e.g. what date should be stored on a polyline that is joined from two lines with different creation dates ..., what happens with items you insert into a new drawing (are they new created or do they have to take the date from their original drawing) .... and where do you store the date/time of a geometry-modification of type "delete" ... and there are a lot more items to take care of.
    - alfred -
    Alfred NESWADBA
