AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Which assembly file needs for MgFeatureReader classes in Autocad Map3d 2014
1 REPLY 1
naym_rm
655 Views, 1 Reply
Hi there
I am trying to develop a command in .Net for autocad map3d 2014.
I need to use MgFeatureReader  class. Previously I used 2010 and I added
Autodesk.Map.Platform.dll. and it is working. but same dll is not working
for 2014.
Can someone mention me the name of dll that I should use ?
Regards
Naym
1 REPLY 1
norman.yuan
in reply to: naym_rm
MgFeatureReader is in OSGeo.MapGuide.PlatformBase.dll.
If you are doing FDO related development with AutoCAD Map, besides AutoCAD.Map.Platform.dll, you almost alway need the following 3 DLL references:
OSGeo.MapGuide.Foundation.dll
OSGeo.MapGuide.Geometry.dll
Norman Yuan
Drive CAD With Code
”Boost
