Hi there
I am trying to develop a command in .Net for autocad map3d 2014.
I need to use MgFeatureReader class. Previously I used 2010 and I added
Autodesk.Map.Platform.dll. and it is working. but same dll is not working
for 2014.
Can someone mention me the name of dll that I should use ?
Regards
Naym
Solved by norman.yuan. Go to Solution.
MgFeatureReader is in OSGeo.MapGuide.PlatformBase.dll.
If you are doing FDO related development with AutoCAD Map, besides AutoCAD.Map.Platform.dll, you almost alway need the following 3 DLL references:
OSGeo.MapGuide.Foundation.dll
OSGeo.MapGuide.Geometry.dll
