Tammy,
If memory recalls, the point list is 3D, not 2D - so add a Z point to each
vertex = 0.
Scott
"Tammy G" wrote in message
news:29214609.1099501077947.JavaMail.jive@jiveforum2.autodesk.com...
> I am attempting to write code to add my new topology centroids into a
selection set. This will allow me to run through the Object Data that is
attached to them and output it into Oracle. I have my oracle connection up
and running in VBA, but I cant seem to make my selection set work. I am
using some set points as a selection boundary.
> Sub points()
> Dim amap As AcadMap
> Dim acadObj As Object
> Dim ODtb As ODTables
> Dim Prj As Project
> Dim ODrcs As ODRecords
> Dim boolVal As Boolean
> Dim ssetObj As AcadSelectionSet
> Dim i As Integer
> Dim returnObj As AcadObject
> Dim basePnt As Variant
> Dim fType(1) As Integer
> Dim fData(1) As Variant
> 'Dim Lst(1, 1) As Variant
> Dim pntLst(7) As Variant
> 'first attempt at point list
> 'Lst(0, 0) = Array(474000, 5450000)
> 'Lst(1, 1) = Array(495000, 5480000)
> 'x coord then y coord for lower left, upper left, upper right and lower
right.
> pntLst(0) = 474000
> pntLst(1) = 5450000
> pntLst(2) = 474000
> pntLst(3) = 5480000
> pntLst(4) = 495000
> pntLst(5) = 5480000
> pntLst(6) = 495000
> pntLst(7) = 5450000
> 'sets up the map
> Set amap =
ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
> 'sets the table collection
> Set Prj = amap.Projects.Item(ThisDrawing)
> Prj.ProjectOptions.DontAddObjectsToSaveSet = True
> Set ODtb = Prj.ODTables
> 'sets the records collection
> Set ODrcs = ODtb.Item("Identity_data").GetODRecords
> 'adds new objects to the selection set
> fType(0) = 0
> fType(1) = 8
> fData(0) = "Point"
> fData(1) = "0"
> Set ssetObj = ThisDrawing.SelectionSets.Add("SS01")
> 'attempting to add all centriods on layer "0" to selection
> ssetObj.SelectByPolygon acSelectionSetWindowPolygon, pntLst, fType, fData
> MsgBox ssetObj.COUNT
> For Each acadObj In ssetObj
> boolVal = ODrcs.Init(ssetObj, True, False)
> MsgBox ODrcs.Record.tableName
> MsgBox ODrcs.Record.ObjectID
> For i = 0 To ODrcs.Record.COUNT - 1
> MsgBox ODrcs.Record.Item(i).Value
> Next i
> Next
> End Sub
> Does anyone know what Im doing wrong. Sorry if I am posting too much, I
am very behind schedule.
> Thanks,
> Tammy
