AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Topology Element ID from a Closed Polyline
1 REPLY 1
550 Views, 1 Reply
I'm a newbie at both MAP and customizing MAP.  I'm having a little trouble with data access.  I have successfully created a Topology and then created closed Polylines from it with the option to copy the Centroid data to the polyline.  The Centroid data shows up when I select the polyline using "Edit Object Data".
I want to retrieve the Element ID from the polyline so I can reference the centroid and its data.  Since there is obviously an association between the two somewhere, how do I extract this field?
Thanks in advance.
J Leavitt
1 REPLY 1
Did you check the following TopologyModel:: GetEntityId Method -> Retrieves the object ID of the AutoCAD entity associated with the specified topology element ID in the current drawing or source drawing.
Does it help ?
”Boost
