Summit Professional & autodesk map 3d
iam Using the Summit Professional with the map 3d ,,,and i have a question about Osnap or the 3dsnap...
Iam using Stealth 3d Mouse model S3-Z... .
hala my question is i want to activate the osnap or the 3dsnaop when iam drawing through the 3d mouse i manage 2 activate the osnap throught the mouse but before i start drawing using Button manager usercad : "{ESC}{ESC}Set{RET}Osmode{RET}673{RET}" and deactivate it with {ESC}{ESC}Set{RET}Osmode{RET}0{RET}..
is there a way to activate the osnap from command line when iam drawing so i can but it as a user cad and activate it..
i tried to click this button when iam drawing it changes the segmnets of the autoarc ... it take the command S ..and ask for a integer number ....
George Khoury
IT department
Good Shepherd for engineering and computing
Daniel.Du
Sorry but I am not clear your question, but it seems that you are asking about OSMode, which is a vinilla AutoCAD feature, not Map 3D specific, so I would suggest you to asking in AutoCAD board to get more specifc answers.
Sorry for not being helpful.
Daniel Du
Developer Technical Services
Autodesk Developer Network
