AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Show records from non-spatial tables
2 REPLIES 2
693 Views, 2 Replies
HI all!
I have map with FDO connection. In my base on server I have tables with geo data objects and other tables without geo data - street names, some specifications and other info. I want read and use data from non-spatial tables in my code. Somebody know how do it right?
2 REPLIES 2
There is a solution because in the past we also ask the Autodesk develop team. If you have ADN account you can find there the solution.
Kalmy
Daniel.Du
You can manupulate non-spatial data source using common database technolegies, ADO.net for example.
And I have a feeling that the same way to manupulate datasource with geomtry field works for non-spatial tables as well. Here is a code snippet to insert data into non-spatial table, just FYI.
        [CommandMethod("InsertNoFeatureClass")]
        public void InsertNonFeatureClass()
            const string LAYERNAME = "FeatModel";
            MgFeatureService featuerSvc = AcMapServiceFactory.GetService(MgServiceType.FeatureService) as MgFeatureService;
            //This is just for demonstration of the format of FeatureSourceId
            AcMapMap currentMap = AcMapMap.GetCurrentMap();
            MgLayerBase layer = null;
            MgLayerCollection allLayers = currentMap.GetLayers();
            foreach (MgLayerBase lyr in allLayers)
                if (lyr.Name == LAYERNAME)
                    layer = lyr;
                    break;
           //Just to demonstrate the format of FeatureSource
            System.Windows.Forms.MessageBox.Show(layer.FeatureSourceId);
            //Library://SDF_1.FeatureSource
            // Insert into feature class
            MgResourceIdentifier featureSourceId = new MgResourceIdentifier("Library://SDF_1.FeatureSource");
            string className = "TTT:FeatData";
            MgPropertyCollection properities = new MgPropertyCollection();
            int randomFeatId = new Random().Next(100);
            properities.Add(new MgInt32Property("FeatId",randomFeatId));
            properities.Add(new MgStringProperty("FeatDes","Test"+randomFeatId.ToString()));
            MgInsertFeatures insFeature = new MgInsertFeatures(className, properities);
            MgFeatureCommandCollection commands = new MgFeatureCommandCollection();
            commands.Add(insFeature);
            featuerSvc.UpdateFeatures(featureSourceId,commands,false);
Daniel Du
Developer Technical Services
Autodesk Developer Network
”Boost
