• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D Developer
    Set FDO layer filter
    308 Views, 3 Replies
    07-13-2012 07:51 AM
    Hi all,
       I need to set a fillter for all fdo layer in a map (as Query to filter data command).
    To do this I wrote this code but the filter is not set. If I manualy run the "Query to filter data" command
    If you launch the "Query to filter data" command manually  on a layer i find the filter set, and is applied only if I press the Ok or Apply button.I think that in my code is missing an instruction to apply the filter set.
    Can you help me?
    Dim objLayers As MgLayerCollection = objMap.GetLayers()
            For Each objLayer As MgLayerBase In objLayers
                Dim objLayerDefId As MgResourceIdentifier = objLayer.GetLayerDefinition()
                Dim objByteReader As MgByteReader = objResourceServ.GetResourceContent(objLayerDefId)
                Dim objXML As XmlDocument = New XmlDocument()
                Dim objSerializer As New XmlSerializer(GetType(LayerDefinition))
                Dim objLayerV As LayerDefinition = TryCast(objSerializer.Deserialize(New StringReader(objByteReader.ToString)), LayerDefinition)
                Dim objVectorLayerDef As VectorLayerDefinitionType = TryCast(objLayerV.Item, VectorLayerDefinitionType)
                objVectorLayerDef.Filter = strFilter
                Dim objXs As New XmlSerializer(objLayerV.[GetType]())
                Dim objWriter As New StringWriter()
                objXs.Serialize(objWriter, objLayerV)
                Dim objBuffer As Byte() = StringToBytes(objWriter.ToString())
                Dim objSource As New MgByteSource(objBuffer, objBuffer.Length)
                ' Update the resource in Map
                objResourceServ.SetResource(objLayer.LayerDefinition, objSource.GetReader(), Nothing)
                objLayer.ForceRefresh()
            Next
    Regards
    Matteo Conte
    Please use plain text.
    ADN Support Specialist
    Re: Set FDO layer filter
    08-05-2012 08:15 PM in reply to: matteo.conte
    Have you ever refered to the QueryAndLocate  and FeatureInspector sample in Map 3D SDK?
    Daniel Du
    Developer Technical Services
    Autodesk Developer Network
    08-05-2012 09:39 PM in reply to: matteo.conte
    Matteo had contacted DevTech / ADN team on this issue and I worked with him to resolve this; It's now resolved.
    Once you update the XML LayerDefinition, you need to update the resource in Map and then call the layer.ForceRefresh(). Here is the relevant code snippet :
    // Update the resource in Map
    ResourceService.SetResource(layer.LayerDefinition, source.GetReader(), null);
    // layer.ForceRefresh();
    Partha Sarkar
    dr5156
    10-25-2012 06:13 AM in reply to: Partha.Sarkar
    i am having same issue. but your solution is not working for me. could you please review my below code
    //Select Entity on Map
    Editor acEditor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
    SelectionSetss = GetAcSelectionSetSingleGeom(acEditor);
    ObjectIdCollection objIdColle = newObjectIdCollection(ss.GetObjectIds());
    MgSelectionBase mgSe = AcMapFeatureEntityService.GetSelection(ss);
    AcMapMap acMap = AcMapMap.GetCurrentMap();
    MgLayerCollectionmgLayColl = acMap.GetLayers();
    MgLayerBase parcelsLayer1 = mgLayColl.GetItem("EL_ADMIN_AREA");
    stringfcName1 = parcelsLayer1.GetFeatureClassName();
    intII = mgSe.GetSelectedFeaturesCount(parcelsLayer1, fcName1);
    MgFeatureReader featureReader = mgSe.GetSelectedFeatures(parcelsLayer1, parcelsLayer1.FeatureClassName, true);
    MgFeatureService fs = AcMapServiceFactory.GetService(MgServiceType.FeatureService) asMgFeatureService;
    if(featureReader.ReadNext())
    stringgeometryName = parcelsLayer1.GetFeatureGeometryName();
    MgByteReadergeometryData = featureReader.GetGeometry(geometryName);
    MgAgfReaderWriter agfReaderWriter = newMgAgfReaderWriter();
    MgGeometrygeometry = agfReaderWriter.Read(geometryData);
    MgPolygon mgPoly = geometry asMgPolygon;
    MgWktReaderWriter wktReaderWriter = newMgWktReaderWriter();
    stringwkt = wktReaderWriter.Write(mgPoly);
    wkt = wkt.Replace(
    "POLYGON", "POLYGON XYZ ");
    wkt = wkt.Replace(
    ",", " 0,");
    wkt = wkt.Replace(
    "))", " 0))");
    string filter = "GEOM INSIDE GeomFromText('" + wkt + "')";
    AcMapLayer layer1 = mgLayColl.GetItem("EL_CONDUCTOR") asAcMapLayer;
    MgResourceIdentifierlayerDefId = layer1.GetLayerDefinition();
    MgResourceService rs = AcMapServiceFactory.GetService(MgServiceType.ResourceService) asMgResourceService;
    MgByteReaderlayerReader = rs.GetResourceContent(layerDefId);
    XmlDocument objXML = newXmlDocument();
    XmlSerializer objSerializer = newXmlSerializer(typeof(LayerDefinition));
    LayerDefinition objLayerDef = objSerializer.Deserialize(newStringReader(layerReader.ToString())) asLayerDefinition;
    VectorLayerDefinitionType objVectorLayerDef = objLayerDef.Item asVectorLayerDefinitionType;
    objVectorLayerDef.Filter = filter;
    using (StringWriter objWriter = newStringWriter())
    XmlSerializer objXs = newXmlSerializer(typeof(LayerDefinition));
    objXs.Serialize(objWriter, objLayerDef);
    byte[] unicodeBytes = Encoding.Unicode.GetBytes(objWriter.ToString());
    byte[] utf8Bytes = Encoding.Convert(Encoding.Unicode, Encoding.UTF8, unicodeBytes);
    MgByteSource objSource = newMgByteSource(utf8Bytes, utf8Bytes.Length);
    rs.SetResource(layer1.LayerDefinition, objSource.GetReader(),
    null);
    layer1.ForceRefresh();
    //layer1.NeedsRefresh();
    if (featureReader != null)
    featureReader.Close();
