Can someone provide an example or link on how to create a propertyalteration in a query using C# or VB?
I have found the ObjectARX example >>here<< but my C skills are very limited. If someone could tell me how to add that to >>this<< I will be forever in your debt.
I am to the point where I can query text objects from a layer, but I need to know how to put them on to a different layer ("TEST" for example).
I should have waited. I found the answer in the Map SDK examples in SessionSampleCommand.cs.
<CommandMethod("q8")> _ Sub q_8() Dim prjModel As ProjectModel = HostMapApplicationServices.Application.ActiveProject prjModel.Options.MarkObjectsForEditingWithoutPrompting = True Dim dwgset As DrawingSet = prjModel.DrawingSet dwgset.AttachDrawing("some dwg file") Dim qryModel As QueryModel = prjModel.CurQuery qryModel.Mode = QueryType.QueryDraw qryModel.Clear() Dim qryRoot As QueryBranch = QueryBranch.Create() 'location Dim loccond As LocationCondition = New LocationCondition() loccond.LocationType = LocationType.LocationInside Dim polypts As New Point3dCollection() polypts.Add(New Point3d(p1x,p1y,p1z)) polypts.Add(New Point3d(p2x,p2y,p2z)) polypts.Add(New Point3d(p3x,p3y,p3z)) polypts.Add(New Point3d(p4x,p4y,p4z)) Dim qpoly As New PolygonBoundary(polypts) loccond.Boundary = qpoly Dim qblocation As QueryBranch = QueryBranch.Create() qblocation.AppendOperand(loccond) qryRoot.AppendOperand(qblocation) 'properties Dim propcond As PropertyCondition = New PropertyCondition() propcond.JoinOperator = JoinOperator.OperatorAnd propcond.PropertyType = PropertyType.Layer propcond.ConditionOperator = ConditionOperator.ConditionEqual Dim thelayers As String = "CSV source layer names" propcond.Value = thelayers Dim qbproperty As QueryBranch = QueryBranch.Create() qbproperty.AppendOperand(propcond) qryRoot.AppendOperand(qbproperty) ' Dim prop2 As PropertyCondition = New PropertyCondition() prop2.JoinOperator = JoinOperator.OperatorAnd prop2.PropertyType = PropertyType.EntityType prop2.ConditionOperator = ConditionOperator.ConditionEqual prop2.Value = "TEXT" Dim qbprop2 As QueryBranch = QueryBranch.Create() qbprop2.AppendOperand(prop2) qryRoot.AppendOperand(qbprop2) 'alter prop Dim propdef As PropertyAlterationDefinition = qryModel.PropertyAlteration Dim propalterlayer As PropertyAlteration = Nothing propalterlayer = propdef.AddAlteration(AlterationType.AlterationLayer) propalterlayer.Expression = "TEST" Dim propalterstyle As PropertyAlteration = Nothing propalterstyle = propdef.AddAlteration(AlterationType.AlterationStyle) propalterstyle.Expression = "STANDARD" qryModel.EnablePropertyAlteration(True) qryModel.Define(qryRoot) Dim queriedobjids As ObjectIdCollection = qryModel.Execute(dwgset) End Sub
Thanks for >>this<< djonio!
