AutoCAD Map 3D Developer
Active Member
kaarigar
Message 1 of 3 (831 Views)
Problem with Query - x64VBAServer has stopped working
831 Views, 2 Replies
08-17-2011 06:54 PM
Environment: AutoCAD Map 3D 2011 + Update 2 , Windows 7 Ultimate 64bit, 64bit VBA
The VBA crashes when I attempt the following in order to query from an attached drawing. The error I get is: x64VBAServer has stopped working. The error happens at the code as commented below. Can anyone tell me what should be done to avoid it?
Sub DoQuery()
    Dim pMap As AcadMap
    Set pMap = ThisDrawing.Application.GetInterfaceObject("Autocadmap.application")
    Dim pProj As Project
    Set pProj = pMap.Projects.Item(0)
    'Dim pDrgSet As DrawingSet
    'Set pDrgSet = pProj.DrawingSet
    Dim pAttDwg As AttachedDrawing
    Set pAttDwg = pProj.DrawingSet.Add("C:\\Temp\\Ceometric.dwg")
    Dim pQry As Query
    Set pQry = pProj.CurrQuery
    pQry.Clear
    'Main Query Branch
    Dim pMainQryBranch As QueryBranch
    Set pMainQryBranch = pQry.QueryBranch
    'Query Leaf to hold a location query
    Dim pQryLeaf As QueryLeaf
    Set pQryLeaf = pMainQryBranch.Add(kAllBoundary, kOperatorAnd) '<<ERROR HAPPENS HERE
    'Define the query
    Debug.Print "Query Define: " & pQry.Define(pMainQryBranch)
    'Execute the query
    pQry.Execute
End Sub
Active Member
kaarigar
Message 2 of 3 (816 Views)
Re: Problem with Query - x64VBAServer has stopped working
08-19-2011 05:47 PM in reply to: kaarigar
Anyone, please?
New Member
NwilsonUT
Message 3 of 3 (371 Views)
04-09-2013 01:51 PM in reply to: kaarigar
I'm experiencing the exact same thing when I'm trying to assign a queryleaf to the root branch. Anyone know how to fix this? It works fine in AutoCAD Map 2011 32 bit but in AutoCAD Map 2011 64 bit, it does not work.
You are not logged in.
Ask the Community
