AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Problem with ObjectData (VB.Net)
4 REPLIES 4
lpleducgroupetanguay
1540 Views, 4 Replies
I'm having a problem with ObjectData.
-- See code below for reference --
I'm calling the function attachODAndSetValue several times through a For statement (For each id in ObjectIDList).
Eventually, I alway get the following error:
Attempted to read or write protected memory.  This is often an indication that other memory is corrupt.
The error always refer to the following line of my code: table.AddRecord(rec, id)
Before calling attachODAndSetValue, I make sure that the ObjectID passed to the function is valid (I check if id.isValid = True).
Did some of you had this kind of problem with ObjectData?  Did you find a solution?
I'm using  AutoCAD MAP 3D 2010 64bits on Windows 7
Louis
    Public Function attachODAndSetValue(ByVal tableName As String, ByVal id As ObjectId, ByVal dataCol As Collection) As Integer
        'tableName : ObjectData Table to attach to the Object
        'id : objectId of the element to which I want to attach the ObjectData
        'dataCol : data to write in the ObjectData
        Dim errStatus As Integer = 0
        Dim rec As Record = Nothing
        Try
            Dim mapApp As Autodesk.Gis.Map.MapApplication = Autodesk.Gis.Map.HostMapApplicationServices.Application
            Dim activeProject As Project.ProjectModel = mapApp.ActiveProject
            Dim tableList As Tables = activeProject.ODTables
            If tableList.IsTableDefined(tableName) = False Then
                'table does not exist, exit try
                errStatus = 2
                Exit Try
            Dim table As ObjectData.Table = tableList.Item(tableName)
            'Create and Initialize the record
            rec = ObjectData.Record.Create
            table.InitRecord(rec)
            If rec.Count = dataCol.Count Then
                Dim i As Integer
                For i = 0 To rec.Count - 1
                    'Assign the value
                    rec.Item(i).Assign(dataCol.Item(i + 1))
                Next
            Else
                errStatus = 3
                Exit Try
            table.AddRecord(rec, id) 'Program crashed here
            errStatus = 0
        Catch err As MapException
            MessageBox.Show("Error:" & vbNewLine & err.Message & vbNewLine & vbNewLine & err.ToString)
            errStatus = 1
        Finally
            If rec IsNot Nothing Then
                rec.Dispose()
        End Try
        Return errStatus
    End Function
4 REPLIES 4
Have you downloaded the Map ObjectARX SDK 2011?  In the Docs folder, the sdk.arx.net.dev.chm file has a section on Object Data and Attaching.  Quoting the doc:
"Each Item property in the record is of type Utilities.MapValue, which is a general-purpose class for storing data of variant types. To set any field, get a reference to the field from the Record object using the Item property. Assign the value with MapValue.Assign()."
Have you checked your datacol.item(i+1)?  Does it exist?  Is it valid for the field type (rec.item(i))?
Yes, the data type is OK
The problem occurs occasionally (8 out of 10 times).
 Sometimes the program works, sometimes it doesn't.
The only way I found to make it work was to call the GarbageCollector at the end of attachODAndSetValue or to dispose of tableList,  activeProject and mapApp.  This make the program super SLOOWWW.
I also tried to create tableList, activeProject and mapApp outside attachODAndSetValue and pass tableList as an argument and it still doesn't work.
What is annoying is that program has been working perfectly for 4-5 years on an old P4 3GHz.  When we got à new i7 940, last year, I started to have occasional problems.  We just migrated to 64 bits and I can't make it run anymore...
I made a counter to display in which of the loop of the for that the program crashed...  It's usually around the 400th loop (out of 1700).
Hello, I'm having the same problem when adding records ObjectData, also decided in the function call GC.Collect (), I use 64-bit AutoCAD MAP 2012, but this solution Deich preventing the application very slow work.
  Can you help me solve this problem please?
Here is how I corrected to problem.
I added a parameter to the function : ODTableList as ObjectData.Tables.
I initialise this variable in the sub calling attachDefaultODAndSetValue
I had to do this modification to every single function using ObjectData but it's been working perfectly since.
Here is an example:
The sub calling attachODAndSetValue
Public Sub button_Click(ByVal sender As  System.Object, ByVal e As System.EventArgs) Handles buttton.Click
Dim ODtableList As ObjectData.tables = Autodesk.Gis.Map.HostMapApplicationServices.Application.ActiveProject.ODTables
Dim myODTable As string = "myODTable"
Dim id As ObjectID
'set a value to id
Dim odCol As new Collection
'Add data to odCol
attachODAndSetValue(ODtableList, myODTable, id, odCol))
End Sub
New version of attachODAndSetValue
PublicFunction attachODAndSetValue(ByVal ODTablesList As ObjectData.Tables, ByVal tableName AsString, ByVal id As ObjectId, ByVal dataCol As Collection) AsInteger
Dim errStatus AsInteger = 0
Try
If ODTablesList.IsTableDefined(tableName) = FalseThen
                    errStatus = 2
                ExitTry
EndIf
Dim table As ObjectData.Table = ODTablesList.Item(tableName)
      Dim i AsInteger
       Next
Else
      errStatus = 3
     ExitTry
EndIf
table.Dispose()
errStatus = 0
            MessageBox.Show("Errorr:" & vbNewLine & err.Message)
            errStatus = 1
Finally
If rec IsNotNothingThen
       rec.Dispose()
EndIf
EndTry
Return errStatus
EndFunction
”Boost
