Hi All,
When i am trying to update a field in Object data using lisp
(ade_odsetfield entName "Service" "InstalledCompletionDate" 0 "2")
it is throwing an error "Ird internal error, Error: 131072 - Internal error". Please let me know how can i reslove this issue.
Kumar.
Hi Kumar,
Which release of Map 3D ? And what's the OS ?
Could you upload a sample DWG file to look into this issue ?
I had similar problem. Use LISP to update the Object data then use 'adeeditdata' to see the data is not updated however
if I extracted the data to text file using ade_odgetfield, the value was correct. Do I need to do anything to refresh the object data?
Joe
