AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Object data error
2 REPLIES 2
giskumar
541 Views, 2 Replies
Object data error
Hi All,
When i am trying to update a field in Object data using lisp
(ade_odsetfield entName "Service" "InstalledCompletionDate" 0 "2")
 it is throwing an error "Ird internal error, Error: 131072 - Internal error". Please let me know how can i reslove this issue.
Kumar.
2 REPLIES 2
Partha.Sarkar
in reply to: giskumar
Hi Kumar,
Which release of Map 3D ? And what's the OS ?
Could you upload a sample DWG file to look into this issue ?
Partha Sarkar
Developer Technical Services
Autodesk Developer Network
joe.yeung
in reply to: Partha.Sarkar
I had similar problem. Use LISP to update the Object data then use 'adeeditdata' to see the data is not updated however
if I extracted the data to text file using ade_odgetfield, the value was correct. Do I need to do anything to refresh the object data?
Joe
Tags (1)
”Boost
