AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
Map Query
0 REPLIES 0
Message 1 of 1
rajeshpatnaik2001
440 Views, 0 Replies
Map Query
HI,
I want to select the objects in the curent drawing which have a specific field value. The table name is "TABLE", and filed name is "FIELD" and the value is "VALUE". In my test drawing, there are two polygons with this table and value.
For that I use the following codes.
To define the query:
(ade_qrydefine '("" "" "" "Data"  ("objdata" "TABLE.FIELD" "=" "VALUE")""))
To execute the query and get the selection set of objects:
(ade_prefsetval "MkSelSetWithQryObj" T)
(if (> (ade_qryexecute) 0.0)
    (setq queried_objects (ssget "P"))
    (princ "\nNo objects found.")
But I am getting at command prompt,
0 object(s) have been queried
and the selection set is empty.
Why I am not getting any objects in query? where is the mistake?
Any help in this regard will be highly appreciated.
Rajesh
0 REPLIES 0
”Boost
