I want to import a raster image (.ECW or .JPG) to my Autocad Map through a development in VB.NET.
I can do it with the command MAPIMPORT as user, but I don't know how to do it in a .NET application.
Thanks a lot
Could this help you?
http://adndevblog.typepad.com/autocad/2012/05/how-to-insert-a-rasterimage-using-the-net-api.html
When you talk about "Map", it is usually very important to pay attention to the coordinates where the image is inserted.
If there is no error, it is likely that the image is being inserted in wrong location (try to zoom to all extension to see if the image is inserted nezr 0,0 coordinate).
Time ago, I had to insert ".ecw"-s, for that, I used to send the "MAPIIMPORT" command to the commandline. Could this be another option?
By the way, this is an extraction of the code I'm using to load images in some of my Apps (I'm sorry that the comments are in Spanish):
''' <summary> ''' Inserta el raster solicitado en el dibujo. ''' </summary> ''' <param name="FileName"></param> ''' <param name="DownLeft"></param> ''' <param name="UpRight"></param> ''' <remarks></remarks> ''' Public Shared Sub InsertRaster(ByVal FileName As String, ByVal Transparent As Boolean, _ ByVal DownLeft As Point3d, ByVal UpRight As Point3d) Try ' Get the current document and database Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim docLock As DocumentLock = acDoc.LockDocument Dim acTrans As Transaction = acDoc.TransactionManager.StartTransaction() Using acTrans Dim idModel As ObjectId = SymbolUtilityServices.GetBlockModelSpaceId(acDoc.Database) Dim ms As BlockTableRecord = TryCast(acTrans.GetObject(idModel, OpenMode.ForWrite), BlockTableRecord) Dim imageDef As RasterImageDef = AddImageDef(acDoc.Database, acTrans, FileName) ', Height, Width) If imageDef IsNot Nothing Then Dim image As New RasterImage() image.ImageDefId = imageDef.ObjectId Dim imageId As ObjectId = ms.AppendEntity(image) If imageId.IsNull Then Throw New Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.NullObjectId) End If 'Con esto se envía la imagen al fondo. Dim dot As DrawOrderTable = DirectCast(acTrans.GetObject(ms.DrawOrderTableId, OpenMode.ForWrite), DrawOrderTable) Dim ids As New ObjectIdCollection() ids.Add(image.ObjectId) dot.MoveToBottom(ids) 'Posicionamiento de la imagen. image.Orientation = New CoordinateSystem3d(DownLeft, New Vector3d(UpRight.X - DownLeft.X, 0, 0), New Vector3d(0, UpRight.Y - DownLeft.Y, 0)) 'Asociación de la imagen con la definición cargada. image.AssociateRasterDef(imageDef) 'La imagen se introducirá en al capa "0" image.Layer = "0" 'Si se requiere, se indica la transparencia de la imagen. If Transparent Then image.DisplayOptions = ImageDisplayOptions.Transparent 'Finalmente se agrega la imagen al dibujo. acTrans.AddNewlyCreatedDBObject(image, True) End If imageDef.Dispose() acTrans.Commit() End Using acDoc.Editor.UpdateScreen() docLock.Dispose() acTrans.Dispose() Catch ex As Exception Debug.Print(ex.Message) End Try End Sub ''' <summary> ''' Agrega una definición de raster al diccionario. ''' </summary> ''' <param name="db"></param> ''' <param name="trans"></param> ''' <param name="imageFilespec"></param> ''' <returns></returns> ''' <remarks></remarks> Private Shared Function AddImageDef(ByVal db As Database, ByVal trans As Transaction, ByVal imageFilespec As String) ', ByVal Height As Double, ByVal Width As Double) As RasterImageDef If Not System.IO.File.Exists(imageFilespec) Then Throw New System.IO.FileNotFoundException(imageFilespec) End If Dim idImageDict As ObjectId = RasterImageDef.GetImageDictionary(db) If idImageDict.IsNull Then idImageDict = RasterImageDef.CreateImageDictionary(db) End If If idImageDict.IsNull Then Throw New InvalidOperationException("failed to get or create image dictionary") End If Dim imageDictionary As DBDictionary = TryCast(trans.GetObject(idImageDict, OpenMode.ForRead), DBDictionary) If imageDictionary Is Nothing Then Throw New InvalidOperationException("Failed to open image dictionary") End If Dim imageDef As New RasterImageDef() imageDef.SourceFileName = imageFilespec imageDef.ResolutionUnits = Unit.Meter imageDef.Load() Dim name As String = ConfigLoader.Config.AppName & "_" & RasterImageDef.SuggestName(imageDictionary, imageFilespec) imageDictionary.UpgradeOpen() Dim idEntry As ObjectId = imageDictionary.SetAt(name, imageDef) imageDictionary.DowngradeOpen() If idEntry.IsNull Then imageDef.Dispose() imageDef = Nothing Throw New InvalidOperationException("Failed to add image definition to image dictionary") End If trans.AddNewlyCreatedDBObject(imageDef, True) Return imageDef End Function
Thanks Alberto. This code loads my image, but I don't know which position (Point3D: DownLeft and UpRight) I have to pass to the merhod InsertRaster.
It is supposed that a ECW file is positionated automatically in its coordenates?
Hello imago69_,
I'm sorry, but when I've inserted ECWs, I had their coordinates in a database to get the points, so I haven't had that problem...
I will try to make some tests to see if I can help you.
Best regards.
Ok Alberto,
I think that I can obtain the coordinates of those points, so I will try and tell you the result.
Thanks a lot!
