Export SDF
Export SDF
Export SDF
Any one have a sample code to export Lines, arcs and plines and their obj data to SDF.
so far all I have been able to do is create a selectset of the objects.
thanks in advance.
Alfred.NESWADBA
check >>>this<<< class ("Using the FDO API in C# .NET" by Scot McFarlane) from AU2009. Yes, it's some time ago and you may need to adopt some signatures used within this class, but it's a real good overview on how to use the FDO-API.
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
The following articles with code samples will be useful to you :
Export DWG to SDF using Autodesk.Gis.Map.ImportExport.Exporter API
http://adndevblog.typepad.com/infrastructure/2012/04/export-dwg-to-sdf-using-autodeskgismapimportexp...
Exporting DWG to SDF using *.epf file using Map 3D API
http://adndevblog.typepad.com/infrastructure/2012/03/exporting-dwg-to-sdf-using-epf-file-using-map-3...
Cheers
