Conversion of AutoCAD Map 2008 VB code to AutoCAD Map 3D VB.NET code
Message 1 of 30
We have a VB application which was written with AutoCAD Map 2008 version.
We now need to re-write the entire application with AutoCAD Map 3D in VB.NET
Can anybody suggest some good specs/pointer?
And the way to do it...
Replies (29)
Message 2 of 30
norman.yuan
It is very difficult to give much useful opinions/suggestions without knowing more details on what you have and you you want to do.
What kind of VB application do you have? is it an external EXE app, or it is VBA code running inside Acad, or it is VB ActiveX DLL project that is loaded into AutoCAD via VBA? What the application does?
When you want to rewrite it with VB.NET, are you going to do it as external EXE app? or if you want to make it DLL project, then do you want to use COM API, or .NET API (AutoCAD .NET API and/or Map .NET API)?
Norman Yuan
Drive CAD With Code
Message 3 of 30
We have Vb 6 ActiveX dll applicatio which we want to convert to VB.NET 2008 DLL.
The application works with drawing files where we can add spaces to the floor of a building.
We can delete spaces as well.
When we want to convert to VB.NET 2008 DLL, we want to use .NET API (AutoCAD map 3D .NET API)
Message 4 of 30
norman.yuan
If you have .NET development experience, I am sure you know VB6 and VB.NET are very different other than their similar syntex. In most cases, there is no way to convert a VB6 project to a sound, workable VB.NET project.
Also, if you intend to use AutoCAD .NET API, then again, it is very different from AutoCAD COM API.
These two factors guarantees that whatever you have done in the VB6 project has to be rewritten with new API (AutoCAD .NET API) and new programming paradigm (.NET).
You can get started with AutoCAD .NET Programming labs, provided by Autodesk, or works on .NET code samples fond in ObjectARX SDK, or check this out:
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html
You may also want to visit and post your question in Autodesk Discussion Group -> AutoCAD -> AutoCAD Customization -> .NET forum, in regarding of generic AutoCAD .NET issue (other than specific AutoCAD Map programming issue).
Norman Yuan
Drive CAD With Code
Message 5 of 30
I have created SDF using a dwg file in AutoCAD Map 3D 2012.
But I am not able to open the SDF file as I don't have a tool to open it.
Could you please suggest a tool to open it so that I can view the features & the layers that are embedded into it?
Could you please tell me the link from where I can download such tool?
Message 6 of 30
Alfred.NESWADBA
Joke? 😉
You have Map3D, why don't you open the SDF with your Map3D then?
You can import it with _MAPIMPORT, you can reference it with _MAPCONNECT.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 30
I am developing a project in VB.NET with AutoCAD Map 3D 2012.
I am opening a dwg file & want to know the layers that are present in the dwg file & then want to process those layers as per the requirement.
I tried to use AcMapMap.GetCurrentMap()
but it is failing, there is no such AcMapMap in AutoCAD Map 3D 2012.
Could you please tell me the way how should I know the name of the dwg file that I m opening & the layers that are present in the file?
Message 8 of 30
Alfred.NESWADBA
what references have you set within your project? I have referenced these dll's
  • Autodesk.Map.Platform.dll
  • Autodesk.Map.Platform.Core.dll
  • OSGeo.MapGuide.Foundation.dll
  • OSGeo.MapGuide.PlatformBase.dll
...to get this running:
Imports Autodesk.AutoCAD
Imports Autodesk.Gis.Map
Imports OSGeo.MapGuide
Public Class cFdoTools
   <Autodesk.AutoCAD.Runtime.CommandMethod("myTools_getFdoLayers")> _
   Public Shared Sub getFdoLayers()
      Dim tLoadedFdoLayer As String = ""
      Try
         Dim tCurrentMap As Platform.AcMapMap = Platform.AcMapMap.GetCurrentMap()
         If (tCurrentMap IsNot Nothing) AndAlso (tCurrentMap.GetLayers IsNot Nothing) Then
            Dim tLayerColl As MgLayerCollection = tCurrentMap.GetLayers
            If (tLayerColl IsNot Nothing) AndAlso (tLayerColl.Count > 0) Then
               For Each tLayer As MgLayerBase In tLayerColl
                  tLoadedFdoLayer &= tLayer.Name & vbNewLine
               Next
         Call MsgBox("Loaded Fdo-Layers: " & vbNewLine & tLoadedFdoLayer)
      Catch ex As Exception
         Call MsgBox("<Your ErrMsg>")
      End Try
   End Sub
End Class
HTH, - alfred -
Alfred NESWADBA
Message 9 of 30
You asked me to add a reference as
But I don't have any such dll present in the AutoCAD install folder as well as ARX folder.
Could you please where would I get these dlls?
I am using AutoCAD Map 3D 2012.
Here I get Map object as Autodesk.Gis.Map.
But I am not able to find Platform in Gis.Map
Message 10 of 30
Alfred.NESWADBA
>> You asked me to add a reference as Autodesk.Map.Platform.dll
I have it in my installation-folder C:\Program Files\Autodesk\AutoCAD Civil 3D 2012 (you will have a Map-directory instead of my Civil one, but the file should be there.
- alfred -
Alfred NESWADBA
Message 11 of 30
Hi
I have a requirement which says, I have to open a dwg file, where I have to select some few polylines and then the selected polylines should be deleted.
I am able to select objects in the dwg file, but not able to delete it.
I am using AutoCAD Map 3D 2012 and VB.NET.
Here I am pasting part of the code that I am having as of now.
Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
            Dim acDoc As Document = acDocMgr.MdiActiveDocument
'Get the selected objects in the drawing area
            Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection()
            MsgBox(acSSPrompt.Status)
            'If the prompt Status is OK, the objects are selected
            If acSSPrompt.Status = PromptStatus.OK Then
                MsgBox("OK")
                'Selection Set for the selected objects
                Dim acSSet As SelectionSet = acSSPrompt.Value
                For Each acSSObj As SelectedObject In acSSet
                Dim myMap As New Autodesk.AutoCAD.DatabaseServices.IdMapping
                Dim myObjs As New Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection
                        If Not IsDBNull(acSSObj) Then
                        'Open the selected object for READ
                        Using trans As Transaction = acDoc.Database.TransactionManager.StartTransaction()
                            Using lock As DocumentLock = acDoc.LockDocument
                                Dim acEnt As Entity = DirectCast(trans.GetObject(acSSObj.ObjectId, OpenMode.ForWrite), Entity)
                                acEnt.UpgradeOpen()
                                acEnt.Erase()
                            End Using
                        End Using
                Next
Message 12 of 30
Alfred.NESWADBA
why do you add your new question to an existing thread? For new questions please create new threads.
And to your code: you haven't commited the transaction 😉
- alfred -
Alfred NESWADBA
Message 13 of 30
Sorry for maintaining the same thread
I will open a new one
And I have committed the transaction, here I put just a part of the code.
Message 14 of 30
Hi
                MsgBox("OK")
                                acEnt.UpgradeOpen()
                                acEnt.Erase()
                            End Using
                        End Using
                     trans.Commit()
                Next
Message 15 of 30
Alfred.NESWADBA
No, with End Using you disposed this transaction, and after acEnt.Erase and before End Using I see not trans.Commit
It does not depend then on any lines after that snippet you showed here.
One more tip: if you opened an object with .ForWrite you don't need the .UpgradeOpen.
- alfred -
Alfred NESWADBA
Message 16 of 30
Alfred.NESWADBA
now you are commiting the transaction when it is already disposed ... sorry, but when you run this code you should get exceptions (hope you watch them in VS).
- alfred -
Alfred NESWADBA
Message 17 of 30
I am confused whether I should commit the transaction or not, as I have already disposed the entity.
Edited by
Discussion_Admin
I also merged the two topics into one
Message 18 of 30
Alfred.NESWADBA
You have first to commit the transaction and then dispose it.
       '...do your work, modify your object
       trans.Commit()    'now save the modifications to the database
   End Using     'this disposes the transaction / free up it's ressources
HTH, - alfred -
Alfred NESWADBA
Message 19 of 30
I modified the code for transaction.
I tried to use Light Weight Polyline for deleting the polylines fromt the dwg file.
I have kept that code in bold letter below.
But it gives an error that there is no object as AcadLWPolyline for AutoCAD Map 3D 2012.
I am not not able to proceed on how to delete the polyline.
Please help me out.
Dim acDocMgr As DocumentCollection =Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
                'Step through the objects in the Selection Set
                    'Check to make sure a valid object was returned
                                'Dim acEnt As Entity = DirectCast(trans.GetObject(acSSObj.ObjectId, OpenMode.ForWrite), Entity)
                                Dim entities As New ObjectIdCollection(acSSPrompt.Value.GetObjectIds())
                                For Each oid As ObjectId In entities
                                    If oid.ObjectClass.Name.Equals("AcDbPolyline") Then
                                        Dim pl As Polyline = TryCast(trans.GetObject(oid, OpenMode.ForWrite), Polyline)
                                        Dim acadPl As AcadLWPolyline = TryCast(pl.AcadObject, AcadLWPolyline)
                                        acadPl.Erase()
                                Next
                                trans.Commit() --- Here I commited the transaction & later it was disposed
                            End Using
                        End Using
                Next
Message 20 of 30
Alfred.NESWADBA
you can't cast a Polyline to a AcadLwPolyline, that's the same as trying to cast a Circle to a Line, they are totally different objects.
If you only want to delete specific objects then use the filter-methods during the selection of objects or at least verify the objecttype of the object to delete.
- alfred -
Alfred NESWADBA
