• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D Developer
    Valued Contributor
    ro_fr
    Check if AutoCAD selection set contains FDO features?
    299 Views, 3 Replies
    09-05-2012 05:49 AM
    is there a reliable way to check if selected objects are Map FDO features?
    It seems no checking is done here:
    http://adndevblog.typepad.com/infrastructure/2012/07/using-acmapfeatureentityservicegetselection-to-...
    but checking is done here:
    http://forums.autodesk.com/t5/AutoCAD-Map-3D-Developer/FDO-object-properties-through-GetEntity/td-p/...
    which I haven't tried myself yet but it doesn't look right to me to rely on this construct:
    if (ent.Layer!="*ACMAPDMGISENTITIES") ....
    What I have is:
     MgSelectionBase selectionBase = AcMapFeatureEntityService.GetSelection(selSet);
    but I need to filter out all non-FDO objects in "selSet". Any ideas?
    many thanks,
    Rob
    Please use plain text.
    Valued Contributor
    ro_fr
    Re: Check if AutoCAD selection set contains FDO features?
    09-05-2012 07:04 AM in reply to: ro_fr
    my issue is actually slighty different then described above.
    For me it doesn't matter if there are FDO and CAD objects mixed in the selection set. The problem arises if only CAD objects have been selected. I need to find out if that is the case. But I do not know how.
    If only an ACAD object has been selected I get a System.NullReferenceException. So I added a check whether the object in question is null or not. But it doesn't seem to be null or my check is wrong?
    if (selectionBase != null)
    ...//ok
    else
     return; //stop
    It never follows the Else branch - but then I get the aformentioned exception later on at
    selectionBase.GetLayers().Count
    Any ideas?
    Rob
    09-06-2012 08:39 PM in reply to: ro_fr
    Unless AutoCAD Map has a radically different implementation of MgSelectionBase from MapGuide, the GetLayers() method of MgSelectionBase returns null for empty selections
    So selectionBase.GetLayers() == null means no features selected
    - Jackie
    Valued Contributor
    ro_fr
    09-07-2012 05:12 AM in reply to: jackie.ng
    Hi Jackie,
    many thanks - that's the solution,
    Rob
