AutoCAD Map 3D Developer
Member
DEVR4730
Message 1 of 4 (374 Views)
Autodesk Map 3D 2012 FDO Problems
374 Views, 3 Replies
02-08-2013 11:59 PM
I have a project using FDO version 3.3.0.0. This project need the FDO Path and i put it in Environment Variable, says c:/fdo/bin. This project working good.
Last week i install Autodesk Map 3D 2012, it complain about '
c:\program files\autodesk\autocad map 3d 2012\acmapworkspace.arx cannot find a
procedure that it needs.'  I can't open task pane and any other command. Through some investigation, i found that Autodesk Map 2012 read FDO from the environment variable. If i remove the fdo path in my environment variable than it work. Is it possible to make the map read FDO from its own FDO only, and not from env variable?
Thank
braudpat
Message 2 of 4 (358 Views)
Re: Autodesk Map 3D 2012 FDO Problems
02-13-2013 08:26 AM in reply to: DEVR4730
Hello
Please check your MAP Configuration/Profile with OPTIONS / 1st Tab / 1st Support path
Have you a Path named "...\bin\fdo" among the 7-9 pathes of your MAP/CIVIL ?
If NOT please, add it !
Bye, Patrice
Bye, Pat
Member
DEVR4730
Message 3 of 4 (352 Views)
02-13-2013 03:19 PM in reply to: DEVR4730
Yes I have it. It look like autodesk read fdo path from environment variable first, and then from support path
braudpat
Message 4 of 4 (253 Views)
03-29-2013 08:40 AM in reply to: DEVR4730
Hello
Sorry for the delay, YES I have seen the same bug with Coordinate Systems
when MAP 201X find a specific Environment Variable, it follows always the variable !
No workaround !!
Except finding somewhere in EXE, DLL, ARX of AutoCAD MAP, the famous variable
and patching/replacing a few chars ...
Bye, Pat
Bye, Pat
