• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D Developer
    pwned555
    2012 'Could not load file or assembly 'ManagedMapApi.dll'...
    856 Views, 6 Replies
    06-28-2012 12:45 PM
    Hi, I keep getting the above error when trying to run a custom form in my .Net custom code that uses the ManagedMapApi.dll.  I'm upgrading from AutoCAD Map 3D 2011 to 2012.  In 2011 everything works fine but in 2012 it gives this error.
    I've looked and there is a C:\Program Files\Autodesk\AutoCAD Map 3D 2012\ManagedMapApi.dll just like in the 2011 version.  I've tried referencing the one in the 2011 folder as well as the 2012 folder.  I've changed it from Copy Local -> False to Copy Local -> True and back again with no luck.  I've also tried running all these changes on a computer with just AutoCAD Map 3D 2012 and no 2011 installed on it.  I've tried it with No service pack upgrades, SP1 and SP2 and still no luck.
    Any help would be appreciated, thanks.
    Please use plain text.
    Re: 2012 'Could not load file or assembly 'ManagedMapApi.dll'...
    07-02-2012 11:48 PM in reply to: pwned555
    not checked that now, but I'm quite sure that this was repaired in one of the service-packs for Map3D.
    - alfred -
    Alfred NESWADBA
    pwned555
    07-03-2012 10:07 AM in reply to: pwned555
    Thanks for the reply, I have SP2 installed on both machines and have referenced the ManagedMapApi.dll from the AutoDesk folder after SP2 was installed.
    07-03-2012 10:29 AM in reply to: pwned555
    can you copy the hole content of the messages (of your error-dialog visible in your screenshot) to a text-file and upload this here?
    BTW: why does your app create an exception while Map3D is loading? If you have it set to be loaded while startup then undo this change and try to load your app after Map3D has finished initialization.
    - alfred -
    Alfred NESWADBA
    pwned555
    07-19-2012 02:33 PM in reply to: pwned555
    So even when I try to do a netload and then find the ManagedMapApi.dll in C:\Program Files\Autodesk\AutoCAD Map 3D 2012\ManagedMapApi.dll it gives me the following error, however when I do the same in Map 2011 it properly loads ManagedMapApi.dll with no error. It also gives this error on two different installs of Map 3D 2012 so it's not because of a random install problem.
    Cannot load assembly. Error details: System.IO.FileNotFoundException: Could not
    load file or assembly 'ManagedMapApi.dll' or one of its dependencies. The
    specified module could not be found.
    File name: 'ManagedMapApi.dll'
    at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String
    codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint,
    StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean
    forIntrospection, Boolean suppressSecurityChecks)
    at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName
    assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean
    at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile,
    Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm
    hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks,
    StackCrawlMark& stackMark)
    at System.Reflection.Assembly.LoadFrom(String assemblyFile)
    at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
    at loadmgd()
    The rest of the message from above is this:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.FileNotFoundException: Could not load file or assembly 'ManagedMapApi.dll' or one of its dependencies. The specified module could not be found.
       at MGICAD.drawingSetting.getCS()
       at MGICAD.DrawingSettings.FormInit()
       at MGICAD.DrawingSettings..ctor()
       at MGICAD.MGICom.DrawingSetting()
       at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
       at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
       at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
       at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.0.30319.269 (RTMGDR.030319-2600)
        CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    Acdbmgd
        Assembly Version: 18.2.0.0
        Win32 Version: 18.2.51.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcdbMgd.DLL
    System
        Win32 Version: 4.0.30319.269 built by: RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    AdApplicationFrame
        Assembly Version: 0.0.0.0
        Win32 Version: 3.2.23.0
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AdApplicationFrame.DLL
    msvcm90
        Assembly Version: 9.0.30729.6161
        Win32 Version: 9.00.30729.6161
        CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll
    AdWindows
        Assembly Version: 3.2.25.0
        Win32 Version: 3.2.25.0
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AdWindows.DLL
    PresentationFramework
        Win32 Version: 4.0.30319.275
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    WindowsBase
        Win32 Version: 4.0.30319.275 built by: RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationCore
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
    System.Xaml
        Win32 Version: 4.0.30319.1 built by: RTMRel
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
    System.Core
        Win32 Version: 4.0.30319.233 built by: RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PresentationFramework.Aero
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
    System.Drawing
        Win32 Version: 4.0.30319.282 built by: RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Acmgd
        Win32 Version: 18.2.205.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/Acmgd.DLL
    System.Configuration
        Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    AcWindows
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcWindows.DLL
    AcCui
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcCui.DLL
    AcWindows.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/en-US/AcWindows.resources.DLL
    AcCustomize
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcCustomize.DLL
    AcCustomize.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/en-US/AcCustomize.resources.DLL
    System.Windows.Forms
        Win32 Version: 4.0.30319.278 built by: RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    AcWelcomeScreen
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcWelcomeScreen.DLL
    AcWelcomeScreen.resources
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/en-US/AcWelcomeScreen.resources.DLL
    AcMapInfoCenter
        Assembly Version: 15.0.204.1
        Win32 Version: 15.0.204.1
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcMapInfoCenter.DLL
    AcWorkspaceSelector
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/AcWorkspaceSelector.DLL
    ManagedMC3
        Assembly Version: 5.8.0.0
        Win32 Version: 5.8.0.0
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/ManagedMC3.DLL
    Topobase.FeatureSearch
        Assembly Version: 9.0.204.0
        Win32 Version: 9.00.204.00
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.FeatureSearch.DLL
    Topobase.Genuine
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Genuine.DLL
    Topobase.Forms
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Forms.DLL
    Topobase.Map
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.DLL
    Topobase.PlugInHandler
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.PlugInHandler.DLL
    Topobase.ImageResources
        Assembly Version: 9.0.53.0
        Win32 Version: 9.00.53.00
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.ImageResources.DLL
    Topobase.Map.GWS.TBExporter.UI
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.GWS.TBExporter.UI.DLL
    Topobase.Map.Loader
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.Loader.DLL
    log4net
        Assembly Version: 1.2.10.0
        Win32 Version: 1.2.10.0
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/log4net.DLL
    Topobase.Config
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Config.DLL
    Topobase.Logging
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Logging.DLL
    Topobase.ExceptionDialog
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.ExceptionDialog.DLL
    Topobase.Exception
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Exception.DLL
    Topobase.Services
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Services.DLL
    Topobase.Collections
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Collections.DLL
    Topobase.FeatureServiceListener
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.FeatureServiceListener.DLL
    Topobase.Tools
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Tools.DLL
    Autodesk.Map.Platform.Core
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/Autodesk.Map.Platform.Core.DLL
    OSGeo.MapGuide.PlatformBase
        Assembly Version: 2.3.0.5080
        Win32 Version: 1.0.0.1
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/OSGeo.MapGuide.PlatformBase.DLL
    OSGeo.MapGuide.Foundation
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/OSGeo.MapGuide.Foundation.DLL
    Topobase.RibbonItems
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.RibbonItems.DLL
    MGICAD
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Maltais%20Geomatics%20Inc/MGICAD.dll
    ContextualTabSelectorRules
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcWindows.dll
    AcMapRibbonWrapper
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcMapRibbonWrapper.DLL
    AcMapRibbon
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcMapRibbon.DLL
    Topobase.Map.AutoCAD.ContextualTabHelper
        CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.AutoCAD.ContextualTabHelper.DLL
    WindowsFormsIntegration
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
    Autodesk.AutoCAD.Interop
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.dll
    Autodesk.AutoCAD.Interop.Common
        CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop.Common/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.Common.dll
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 10.0.30319.1 built by: RTMRel
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Thanks for the help, don't know if that extra information will be helpful or not.
    07-20-2012 01:39 AM in reply to: pwned555
    what happens if you create a small new project just referencing the dll and create a function that uses a small part of this lib.
    Do you then also get an error?
    I see the second part of the message more important than the first as I don't think that you have a defect ManagedMapApi.dll (as you have done a full installation and you have upgraded all servicepacks for Map3D). So loading of this dll seems to miss some other parts to be able to get initialized. And maybe that you miss some support-paths in Map? E.g. to the directories with the FDO-bin's? Verify that or start with an AutoCAD-profile that is original or that you import from another pc or create a new Windows-user and try it within his environment (to build your sample project).
    - alfred -
    Alfred NESWADBA
    pwned555
    07-20-2012 03:02 PM in reply to: pwned555
    Thank you it did have to do with FDO->Bin directory.  My custom profile was set to install location \FDO\Bin for Map 3D 2011, however for some reason this was change for Map 3D 2012 to \bin\fdo... Extremely annoying as I had it based on install location and everything seemed to be changing correctly for 2012.
    Thanks again for the help.
