AutoCAD Map 3D Developer
Welcome to Autodesk’s AutoCAD Map 3D Developer Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D Developer topics.
2012 'Could not load file or assembly 'ManagedMapApi.dll'...
6 REPLIES 6
4968 Views, 6 Replies
Hi, I keep getting the above error when trying to run a custom form in my .Net custom code that uses the ManagedMapApi.dll.  I'm upgrading from AutoCAD Map 3D 2011 to 2012.  In 2011 everything works fine but in 2012 it gives this error.
I've looked and there is a C:\Program Files\Autodesk\AutoCAD Map 3D 2012\ManagedMapApi.dll just like in the 2011 version.  I've tried referencing the one in the 2011 folder as well as the 2012 folder.  I've changed it from Copy Local -> False to Copy Local -> True and back again with no luck.  I've also tried running all these changes on a computer with just AutoCAD Map 3D 2012 and no 2011 installed on it.  I've tried it with No service pack upgrades, SP1 and SP2 and still no luck.
Any help would be appreciated, thanks.
6 REPLIES 6
Alfred.NESWADBA
not checked that now, but I'm quite sure that this was repaired in one of the service-packs for Map3D.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Thanks for the reply, I have SP2 installed on both machines and have referenced the ManagedMapApi.dll from the AutoDesk folder after SP2 was installed.
Alfred.NESWADBA
can you copy the hole content of the messages (of your error-dialog visible in your screenshot) to a text-file and upload this here?
BTW: why does your app create an exception while Map3D is loading? If you have it set to be loaded while startup then undo this change and try to load your app after Map3D has finished initialization.
- alfred -
Alfred NESWADBA
So even when I try to do a netload and then find the ManagedMapApi.dll in C:\Program Files\Autodesk\AutoCAD Map 3D 2012\ManagedMapApi.dll it gives me the following error, however when I do the same in Map 2011 it properly loads ManagedMapApi.dll with no error. It also gives this error on two different installs of Map 3D 2012 so it's not because of a random install problem.
Cannot load assembly. Error details: System.IO.FileNotFoundException: Could not
load file or assembly 'ManagedMapApi.dll' or one of its dependencies. The
specified module could not be found.
File name: 'ManagedMapApi.dll'
at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String
codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint,
StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean
forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName
assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean
at System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile,
Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm
hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks,
StackCrawlMark& stackMark)
at System.Reflection.Assembly.LoadFrom(String assemblyFile)
at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(String fileName)
at loadmgd()
The rest of the message from above is this:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'ManagedMapApi.dll' or one of its dependencies. The specified module could not be found.
   at MGICAD.drawingSetting.getCS()
   at MGICAD.DrawingSettings.FormInit()
   at MGICAD.DrawingSettings..ctor()
   at MGICAD.MGICom.DrawingSetting()
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.269 (RTMGDR.030319-2600)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
    Assembly Version: 18.2.0.0
    Win32 Version: 18.2.51.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcdbMgd.DLL
System
    Win32 Version: 4.0.30319.269 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.2.23.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AdApplicationFrame.DLL
msvcm90
    Assembly Version: 9.0.30729.6161
    Win32 Version: 9.00.30729.6161
    CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83bc251/msvcm90.dll
AdWindows
    Assembly Version: 3.2.25.0
    Win32 Version: 3.2.25.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AdWindows.DLL
PresentationFramework
    Win32 Version: 4.0.30319.275
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
    Win32 Version: 4.0.30319.275 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Core
    Win32 Version: 4.0.30319.233 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
    Win32 Version: 4.0.30319.282 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Acmgd
    Win32 Version: 18.2.205.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/Acmgd.DLL
System.Configuration
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcWindows.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcCui.DLL
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/en-US/AcWindows.resources.DLL
AcCustomize
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcCustomize.DLL
AcCustomize.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/en-US/AcCustomize.resources.DLL
System.Windows.Forms
    Win32 Version: 4.0.30319.278 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
AcWelcomeScreen
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcWelcomeScreen.DLL
AcWelcomeScreen.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/en-US/AcWelcomeScreen.resources.DLL
AcMapInfoCenter
    Assembly Version: 15.0.204.1
    Win32 Version: 15.0.204.1
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcMapInfoCenter.DLL
AcWorkspaceSelector
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/AcWorkspaceSelector.DLL
ManagedMC3
    Assembly Version: 5.8.0.0
    Win32 Version: 5.8.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/ManagedMC3.DLL
Topobase.FeatureSearch
    Assembly Version: 9.0.204.0
    Win32 Version: 9.00.204.00
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.FeatureSearch.DLL
Topobase.Genuine
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Genuine.DLL
Topobase.Forms
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Forms.DLL
Topobase.Map
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.DLL
Topobase.PlugInHandler
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.PlugInHandler.DLL
Topobase.ImageResources
    Assembly Version: 9.0.53.0
    Win32 Version: 9.00.53.00
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.ImageResources.DLL
Topobase.Map.GWS.TBExporter.UI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.GWS.TBExporter.UI.DLL
Topobase.Map.Loader
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.Loader.DLL
log4net
    Assembly Version: 1.2.10.0
    Win32 Version: 1.2.10.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/log4net.DLL
Topobase.Config
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Config.DLL
Topobase.Logging
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Logging.DLL
Topobase.ExceptionDialog
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.ExceptionDialog.DLL
Topobase.Exception
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Exception.DLL
Topobase.Services
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Services.DLL
Topobase.Collections
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Collections.DLL
Topobase.FeatureServiceListener
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.FeatureServiceListener.DLL
Topobase.Tools
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Tools.DLL
Autodesk.Map.Platform.Core
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/Autodesk.Map.Platform.Core.DLL
OSGeo.MapGuide.PlatformBase
    Assembly Version: 2.3.0.5080
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/OSGeo.MapGuide.PlatformBase.DLL
OSGeo.MapGuide.Foundation
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/OSGeo.MapGuide.Foundation.DLL
Topobase.RibbonItems
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.RibbonItems.DLL
MGICAD
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Maltais%20Geomatics%20Inc/MGICAD.dll
ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcWindows.dll
AcMapRibbonWrapper
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcMapRibbonWrapper.DLL
AcMapRibbon
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/AcMapRibbon.DLL
Topobase.Map.AutoCAD.ContextualTabHelper
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map%203D%202012/bin/Topobase.Map.AutoCAD.ContextualTabHelper.DLL
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
Autodesk.AutoCAD.Interop
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.dll
Autodesk.AutoCAD.Interop.Common
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.AutoCAD.Interop.Common/18.2.0.0__eed84259d7cbf30b/Autodesk.AutoCAD.Interop.Common.dll
Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 10.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Thanks for the help, don't know if that extra information will be helpful or not.
Alfred.NESWADBA
what happens if you create a small new project just referencing the dll and create a function that uses a small part of this lib.
Do you then also get an error?
I see the second part of the message more important than the first as I don't think that you have a defect ManagedMapApi.dll (as you have done a full installation and you have upgraded all servicepacks for Map3D). So loading of this dll seems to miss some other parts to be able to get initialized. And maybe that you miss some support-paths in Map? E.g. to the directories with the FDO-bin's? Verify that or start with an AutoCAD-profile that is original or that you import from another pc or create a new Windows-user and try it within his environment (to build your sample project).
- alfred -
Alfred NESWADBA
Thank you it did have to do with FDO->Bin directory.  My custom profile was set to install location \FDO\Bin for Map 3D 2011, however for some reason this was change for Map 3D 2012 to \bin\fdo... Extremely annoying as I had it based on install location and everything seemed to be changing correctly for 2012.
Thanks again for the help.
”Boost
