AutoCAD Map 3D Developer
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
2012 'Could not load file or assembly 'ManagedMa pApi.dll'. ..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, I keep getting the above error when trying to run a custom form in my .Net custom code that uses the ManagedMapApi.dll. I'm upgrading from AutoCAD Map 3D 2011 to 2012. In 2011 everything works fine but in 2012 it gives this error.
I've looked and there is a C:\Program Files\Autodesk\AutoCAD Map 3D 2012\ManagedMapApi.dll just like in the 2011 version. I've tried referencing the one in the 2011 folder as well as the 2012 folder. I've changed it from Copy Local -> False to Copy Local -> True and back again with no luck. I've also tried running all these changes on a computer with just AutoCAD Map 3D 2012 and no 2011 installed on it. I've tried it with No service pack upgrades, SP1 and SP2 and still no luck.
Any help would be appreciated, thanks.
Re: 2012 'Could not load file or assembly 'ManagedMa pApi.dll'. ..
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
not checked that now, but I'm quite sure that this was repaired in one of the service-packs for Map3D.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the reply, I have SP2 installed on both machines and have referenced the ManagedMapApi.dll from the AutoDesk folder after SP2 was installed.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
can you copy the hole content of the messages (of your error-dialog visible in your screenshot) to a text-file and upload this here?
BTW: why does your app create an exception while Map3D is loading? If you have it set to be loaded while startup then undo this change and try to load your app after Map3D has finished initialization.
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So even when I try to do a netload and then find the ManagedMapApi.dll in C:\Program Files\Autodesk\AutoCAD Map 3D 2012\ManagedMapApi.dll it gives me the following error, however when I do the same in Map 2011 it properly loads ManagedMapApi.dll with no error. It also gives this error on two different installs of Map 3D 2012 so it's not because of a random install problem.
Cannot load assembly. Error details: System.IO.FileNotFoundException: Could not load file or assembly 'ManagedMapApi.dll' or one of its dependencies. The specified module could not be found. File name: 'ManagedMapApi.dll' at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks) at System.Reflection.RuntimeAssembly.InternalLoadAsse mblyName(AssemblyName assemblyRef, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection, Boolean suppressSecurityChecks) at System.Reflection.RuntimeAssembly.InternalLoadFrom (String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark) at System.Reflection.Assembly.LoadFrom(String assemblyFile) at Autodesk.AutoCAD.Runtime.ExtensionLoader.Load(Stri ng fileName) at loadmgd()
The rest of the message from above is this:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.IO.FileNotFoundException: Could not load file or assembly 'ManagedMapApi.dll' or one of its dependencies. The specified module could not be found. File name: 'ManagedMapApi.dll' at MGICAD.drawingSetting.getCS() at MGICAD.DrawingSettings.FormInit() at MGICAD.DrawingSettings..ctor() at MGICAD.MGICom.DrawingSetting() at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker WithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.I nvoke(MethodInfo mi, Boolean bLispFunction) at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk .Invoke() ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.269 (RTMGDR.030319-2600) CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0. 30319/mscorlib.dll ---------------------------------------- Acdbmgd Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcdbMgd.DLL ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.269 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 3.2.23.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AdApplicationFrame.DLL ---------------------------------------- msvcm90 Assembly Version: 9.0.30729.6161 Win32 Version: 9.00.30729.6161 CodeBase: file:///C:/Windows/WinSxS/amd64_microsoft.vc90.crt _1fc8b3b9a1e18e3b_9.0.30729.6161_none_08e61857a83b c251/msvcm90.dll ---------------------------------------- AdWindows Assembly Version: 3.2.25.0 Win32 Version: 3.2.25.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AdWindows.DLL ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.275 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /PresentationFramework/v4.0_4.0.0.0__31bf3856ad364 e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.275 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/Window sBase.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.275 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/P resentationCore/v4.0_4.0.0.0__31bf3856ad364e35/Pre sentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System .Xaml.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.233 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Core/v4.0_4.0.0.0__b77a5c561934e089/System .Core.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.233 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System. Xml.dll ---------------------------------------- PresentationFramework.Aero Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856 ad364e35/PresentationFramework.Aero.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.282 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/Sys tem.Drawing.dll ---------------------------------------- Acmgd Assembly Version: 18.2.0.0 Win32 Version: 18.2.205.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/Acmgd.DLL ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 (RTMRel.030319-0100) CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a 3a/System.Configuration.dll ---------------------------------------- AcWindows Assembly Version: 18.2.0.0 Win32 Version: 18.2.205.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcWindows.DLL ---------------------------------------- AcCui Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcCui.DLL ---------------------------------------- AcWindows.resources Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/en-US/AcWindows.resources.DLL ---------------------------------------- AcCustomize Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcCustomize.DLL ---------------------------------------- AcCustomize.resources Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/en-US/AcCustomize.resources.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.278 built by: RTMGDR CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e0 89/System.Windows.Forms.dll ---------------------------------------- AcWelcomeScreen Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcWelcomeScreen.DLL ---------------------------------------- AcWelcomeScreen.resources Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/en-US/AcWelcomeScreen.resources.DLL ---------------------------------------- AcMapInfoCenter Assembly Version: 15.0.204.1 Win32 Version: 15.0.204.1 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcMapInfoCenter.DLL ---------------------------------------- AcWorkspaceSelector Assembly Version: 15.0.204.1 Win32 Version: 15.0.204.1 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/AcWorkspaceSelector.DLL ---------------------------------------- ManagedMC3 Assembly Version: 5.8.0.0 Win32 Version: 5.8.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/ManagedMC3.DLL ---------------------------------------- Topobase.FeatureSearch Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.FeatureSearch.DLL ---------------------------------------- Topobase.Genuine Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Genuine.DLL ---------------------------------------- Topobase.Forms Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Forms.DLL ---------------------------------------- Topobase.Map Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Map.DLL ---------------------------------------- Topobase.PlugInHandler Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.PlugInHandler.DLL ---------------------------------------- Topobase.ImageResources Assembly Version: 9.0.53.0 Win32 Version: 9.00.53.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.ImageResources.DLL ---------------------------------------- Topobase.Map.GWS.TBExporter.UI Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Map.GWS.TBExporter.UI.DLL ---------------------------------------- Topobase.Map.Loader Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Map.Loader.DLL ---------------------------------------- log4net Assembly Version: 1.2.10.0 Win32 Version: 1.2.10.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/log4net.DLL ---------------------------------------- Topobase.Config Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Config.DLL ---------------------------------------- Topobase.Logging Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Logging.DLL ---------------------------------------- Topobase.ExceptionDialog Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.ExceptionDialog.DLL ---------------------------------------- Topobase.Exception Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Exception.DLL ---------------------------------------- Topobase.Services Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Services.DLL ---------------------------------------- Topobase.Collections Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Collections.DLL ---------------------------------------- Topobase.FeatureServiceListener Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.FeatureServiceListener.DL L ---------------------------------------- Topobase.Tools Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Tools.DLL ---------------------------------------- Autodesk.Map.Platform.Core Assembly Version: 15.0.204.1 Win32 Version: 15.0.204.1 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/Autodesk.Map.Platform.Core.DLL ---------------------------------------- OSGeo.MapGuide.PlatformBase Assembly Version: 2.3.0.5080 Win32 Version: 1.0.0.1 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/OSGeo.MapGuide.PlatformBase.DLL ---------------------------------------- OSGeo.MapGuide.Foundation Assembly Version: 2.3.0.5080 Win32 Version: 1.0.0.1 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/OSGeo.MapGuide.Foundation.DLL ---------------------------------------- Topobase.RibbonItems Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.RibbonItems.DLL ---------------------------------------- MGICAD Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Maltais%20Geomatics%20Inc/MGICAD.dll ---------------------------------------- ContextualTabSelectorRules Assembly Version: 0.0.0.0 Win32 Version: 18.2.205.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcWindows.dll ---------------------------------------- AcMapRibbonWrapper Assembly Version: 15.0.204.1 Win32 Version: 15.0.204.1 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcMapRibbonWrapper.DLL ---------------------------------------- AcMapRibbon Assembly Version: 15.0.204.1 Win32 Version: 15.0.204.1 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/AcMapRibbon.DLL ---------------------------------------- Topobase.Map.AutoCAD.ContextualTabHelper Assembly Version: 9.0.204.0 Win32 Version: 9.00.204.00 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Map% 203D%202012/bin/Topobase.Map.AutoCAD.ContextualTab Helper.DLL ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad3 64e35/WindowsFormsIntegration.dll ---------------------------------------- Autodesk.AutoCAD.Interop Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Auto CAD.Interop/18.2.0.0__eed84259d7cbf30b/Autodesk.Au toCAD.Interop.dll ---------------------------------------- Autodesk.AutoCAD.Interop.Common Assembly Version: 18.2.0.0 Win32 Version: 18.2.51.0.0 CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Autodesk.Auto CAD.Interop.Common/18.2.0.0__eed84259d7cbf30b/Auto desk.AutoCAD.Interop.Common.dll ---------------------------------------- Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 10.0.30319.1 built by: RTMRel CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL /Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d5 0a3a/Microsoft.VisualBasic.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Thanks for the help, don't know if that extra information will be helpful or not.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
what happens if you create a small new project just referencing the dll and create a function that uses a small part of this lib.
Do you then also get an error?
I see the second part of the message more important than the first as I don't think that you have a defect ManagedMapApi.dll (as you have done a full installation and you have upgraded all servicepacks for Map3D). So loading of this dll seems to miss some other parts to be able to get initialized. And maybe that you miss some support-paths in Map? E.g. to the directories with the FDO-bin's? Verify that or start with an AutoCAD-profile that is original or that you import from another pc or create a new Windows-user and try it within his environment (to build your sample project).
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you it did have to do with FDO->Bin directory. My custom profile was set to install location \FDO\Bin for Map 3D 2011, however for some reason this was change for Map 3D 2012 to \bin\fdo... Extremely annoying as I had it based on install location and everything seemed to be changing correctly for 2012.
Thanks again for the help.
