• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *scott
    viewport caching
    145 Views, 1 Replies
    07-14-2003 03:11 AM
    I have a project that I worked in BS3 and now am going to be working on in
    BS4. My file got very large, I had 3 xrefs plus work on top of that. When
    switching between the different sheets in the one file and keep getting this
    "viewport caching" and it works very slow and since using it in BS4 the
    program keeps crashing. I have since detached 2 xref's from the file to down
    size it but I am unable to switch between the sheets. I wanted to take those
    tabs and put them in other cad files, to break up the size. Your help is
    greatly appreciated.
    Scott
    Please use plain text.
    Employee
    Re: viewport caching
    07-14-2003 04:46 AM in reply to: *scott
    Hi Scott -
    You can "probably" use design center to pull the layout tabs (copy them) out of the existing drawing and put them in a new drawing. By using design center to access the layout tabs, you may be able to get to more of the data than you would be able to access by opening the drawing and trying to switch tabs. - jason
