• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *JIC
    need help fixing errors
    126 Views, 3 Replies
    12-14-2003 12:00 AM
    I just installed BS2004 and when i start the program i get the errors
    that tell me i cannot get commumication controler. i go to use help to
    fix and there is no help. please help!!!!
    Phil
    Please use plain text.
    *[Autodesk], Bo Noren
    Re: need help fixing errors
    12-14-2003 12:00 AM in reply to: *JIC
    Hi Phil,
    Is it the Communication Center that are causing the error? What are the
    exact error message? What happens after you get the error; can you use the
    application?
    /Bosse
    "JIC" wrote in message
    news:A72AF8F4F3DDFBA1DE19217DE893AB1D@in.WebX.maYIadrTaRb...
    > Phil
    *JIC
    Re:
    i can use the application without a problem. the error message is about
    the commucation center not connecting.
    Bo Noren [Autodesk] wrote:
    > Hi Phil,
    > application?
    > /Bosse
    >>Phil
    Re:
    Hi Phil,
    This problem has been discussed in the newsgroup autodesk.autocad.2004;
    search for "communication". The problem may be related to the firewall if
    you are using one.
    The communication center is a tool for getting updates and product
    information and announcements e t c. You can read more about it in the help
    file for BS2004. Type in the keyword Communication Center in the index tab.
    /Bosse
    news:A24DFA5C6E7DC3AB678EA092A8523BDD@in.WebX.maYIadrTaRb...
    > > Hi Phil,
    the
    > > application?
    > > /Bosse
    > >>Phil
