• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Valued Mentor
    i-drop ContentBrowser ToolPalette Groups into AutoCAD MEP 2013
    422 Views, 3 Replies
    09-11-2012 06:04 PM
    Is anyone having issues with i-drop tool palette groups into AutoCAD MEP 2013?
    Mine won't even drag n drop out of the box palettes.
    see http://forums.augi.com/showthread.php?140670-Content-Browser-i-drop-not-working
    Just wondering how many others?
    I also wonder if this is not an issue that adesk didn't catch with how the vertical product now get loaded? My AutoCAD MEP installed as a sub folder into Acad 2013... at C:\Program Files\Autodesk\AutoCAD 2013\MEP
    Please use plain text.
    Product Support
    Re: i-drop ContentBrowser ToolPalette Groups into AutoCAD MEP 2013
    09-13-2012 12:39 PM in reply to: mdhutchinson
    Mike,
    In the support case, you mentioned this issue was resolved by recreating the tools from scratch in 2013.  I noticed this forum post pre-dates our support case.  Don't know why it was not working the first round.  Should we mark this forum post as solved?  You want to hold off and see if any others have this issue?
    Joshua
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Mentor
    09-13-2012 12:57 PM in reply to: Joshua.Benoist
    The issue is not solved... it just started working on my machine without apparrent explanation as to why.
    I would like to leave this open... and see if others are also having the issue.
    New Member
    10-04-2012 09:33 AM in reply to: mdhutchinson
    We are currently having this same issue in ACAD 2013. I cannot drag and drop items from the content browser into my workspace using the i-drop tool. A work around i have been using is to use the i-drop tool, move the object onto a palette, and then dragging from the palette to my work space.
    Not the best use of our library or the tool.
    I have reinstalled the i-drop program and this has not helped.
    Funny thing is when i first installed 2013 it wokred fine, but got steadily worse until it stopped working.
    Any other suggestions?
