AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
can't move or Stretch dimensions with Grips
5 REPLIES 5
grutha
7553 Views, 5 Replies
I'm using mep2013 when I try and move or stretch a dimension  with the grips the usc goes upside down or offset and the dimension dosen't move or stretch. Any help would be great
5 REPLIES 5
Volker_C
in reply to: grutha
I'd like to help but I'm not understanding the problem, can you give a more detailed description of the process?
It would help to see your workflow, the behavior, and where to look for this issue. There is a free video recorder called http://www.jingproject.com. Please make us a video of the issue. Jing allows you to upload the video to a website called http://www.Screencast.com, for free. Jing places a link to the video onto your computers clipboard. Simply paste that link into a reply to this post and we can then watch it and provide a solution to the problem.
Cheers,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
Volker_C
in reply to: Volker_C
Just checking back to see if you still need help with this?
Cheers,
Volker
Volker C.
peterchristie1938
in reply to: grutha
I had the same problem .. see this thread for an easy workaround
http://forums.autodesk.com/t5/AutoCAD-MEP/Linear-Dimensions-problem-1-was-not-parallel-to-the-ucs/m-...
don't know what changed in ACAD, but this just worked 2012, you didn't have to remember to toggle the Z lock
try setting UCSFOLLOWDIMENSION = 2
grutha
in reply to: peterchristie1938
Thanks looks like that worked
Greg Rutha
N/C DESIGN ENGINEER
PAR PLUMBING CO. INC.
60 North Prospect Ave
Lynbrook, New York 11563
grutha@pargroup.com
516-394-2098 (Office)
516-394-9089 (Fax)
”Boost
