• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Contributor
    blackeagle1245
    bug in hidden lines in block based mvparts ?
    91 Views, 2 Replies
    01-09-2012 04:32 AM
    I created block based mvpart. It has a schematic block in it. And I work in a template that shows mvparts in schematic view. But then when a duct pass over mvpart then it doesnt seem hidden. If I change my mvparts view to plan, then its normal. Is it a bug or just a common thing that mep doesnt show mvparts hidden when they are in schematic view?.
    Active Contributor
    blackeagle1245
    Re: bug in hidden lines in block based mvparts ?
    01-10-2012 06:22 AM in reply to: blackeagle1245
    nobody knows?. Is there hidden lines in schematic view or not?.
    Employee
    01-25-2012 07:56 AM in reply to: blackeagle1245
    If your dispaly configuration is set to only show the Schematic represetnation of the MvParts, then no, it is not expected to show hidden lines.
    You can see this by opening DIsplay Manager, and browsing to Representation By Object > Multi-View Part.  Select Plan, notice on the Layer/Color/Linetype there is Contour, Contour - Hidden, etc... Select Schematic.. now all you see is Contour.
    Martin Schmid, P.E.
    Industry Success Manager
    Architecture, Engineering, and Construction
