• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Valued Contributor
    mjmpe
    autocad crashes when changing view
    181 Views, 3 Replies
    01-10-2013 03:54 AM
    Everytime I change views my drwg goes into a fatal error and crashes. Is there anything I can try to fix this? It is very aggrevating.
    thanks
    Please use plain text.
    Valued Contributor
    Re: autocad crashes when changing view
    01-10-2013 07:31 AM in reply to: mjmpe
    What is your machine build?
    Valued Contributor
    mjmpe
    01-12-2013 11:07 AM in reply to: mjmpe
    NOT SURE WHAT YOU ARE ASKING? I AM ON WINDOWS 7 PROFESSIONAL IF THATS WHAT YOU MEAN.
    Valued Contributor
    01-14-2013 08:00 AM in reply to: mjmpe
    When I first started ACAD MEP, I had a new machine that constantly crashed. I found out the video card was not tested by Autodesk.  I ugraded the machine for a more robust card which fixed the problem. Most of those who work MEP that I know, HVAC, Plumbing..., have a hard time with performance. I think it's the nature of the program. That said, check your work flow to isolate the objects you're editing. By machine, I mean the total package, RAM, processor, video card, just check to make sure it can handle what you're trying to do.
