• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    New Member
    Accepted Solution
    architectural catalogs in MEP 2013
    319 Views, 3 Replies
    08-07-2012 06:19 PM
    I have just upgraded to MEP 2013 from 2012 and have just gone to use the default catalogs in content browser only to find the aec ones missing does anyone know how to install them.
    Regards
    Brian
    Please use plain text.
    *Expert Elite*
    Keith.Brown
    Re: architectural catalogs in MEP 2013
    08-09-2012 09:57 AM in reply to: brian.cervi
    Go into your windows control panel and choose uninstall a program.  Then select Autocad MEP 2013 and choose change.  This will bring up the installer and allow you to install compenents that were not installed the first time around. Choose Add/Remove content and make sure to check the architectural compenents.  You might need your original installation media at this step.  I am not sure though.
    Hope this helps and good luck!
    Keith Brown AutoCAD MEP BLOG | RSS Feed
    Product Support
    08-09-2012 02:01 PM in reply to: Keith.Brown
    You will need the original installation media to install the Architectural content packs, yes.
    Joshua
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Joshua Benoist, PE
    Senior Support Specialist
    Product Support
    Autodesk, Inc.
    Product Support
    08-10-2012 01:10 PM in reply to: Joshua.Benoist
    Following up.  Did the above help?
    Joshua
    Joshua Benoist, PE
    Product Support
    Autodesk, Inc.
