• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *NONE
    Re: ! a question and a suggestion - please read this !
    04-08-2005 11:28 AM in reply to: bil-with-one-L
    thanks "jayportland" wrote in message news:5024085.1112977984488.JavaMail.jive@jiveforum2.autodesk.com... > Quote: Originally posted by NONE > > good stuff!! > > we are just starting adt/abs. > > how long did it take you to reach this level of production? > End Quote. > > Well let me put it this way. The piping layout, and the HVAC that you see > along with all of the equipment took me about 40 hours worth of work. The > majority of that time was spent on creating the MVparts equipment. > > However, I have to be honest, I have spent over 300 hours total time on > this model. Don't get me wrong, the initial production was fast, but the > constant tweaking and design changes that occur durring the life of the > project. What you are not seeing is the basement. That image is only the > ground floor. There is a bunch of stuff on the Roof, and even more in the > basement. Anyway, you get the idea. > > Jay Ayala > Mechanical Designer > Portland Oregon > HDR Inc.
    Please use plain text.
    *Roberto Zenteno
    04-10-2005 08:18 PM in reply to: bil-with-one-L
    Hello:
    This sounds excelent. Quick question? What is the size(MBs) of this library
    you've created. If it is with in reason I can share some pace in my Website.
    Let me know.
    Roberto
    wrote in message news:4806263@discussion.autodesk.com...
    Hey guys,
    Someone mentioned Butterfly valves. I ran into the same problem. I was
    working on a central utility plant design and piping that is up to 30" in
    diameter. I noticed that the standard ABS catalog was defined in an *.xml
    file but it only went to size 12".
    I wound up creating a supplementary catalog that was custom sizes; 14" up to
    30" butterfly valves. I drew each of the valves in solid modeling from the
    manufacture cut sheets with proper dimensions and all of that, then I
    defined the MVbl
    ock views from that 3D model of each of the valves.
    The cool thing about this is that each of the valves was not just a MVPart,
    it had the connectors defined at the appropriate lengths and the schematic
    symbols looked right and the top views were standard 2 line, but the best
    part was that I found a few interferences (valve handle) that I normally
    would not have seen if it was just regular 2D drafting.
    Custom content? Hell yeah!
    Valuable to others? Possibly some day.
    Should this be shared? I wo
    uld like to think so.
    Not only that, but I also had to draw the following:
    ? Custom Chillers
    ? Custom Cooling Towers
    ? Custom Air Handlers
    ? Custom Air Compressors
    ? Custom Expansion Tanks
    ? Custom Split Case Pumps
    ? Custom Air Separators
    ? Custom VFD's
    ? Custom Electrical Pull Boxes
    ? Custom 55 Gallon drums
    ? Custom Diesel Generators
    ? Custom Radiators
    The list goes on and on. I realize that I might be using some of these
    items in future projects and that I should organize my drawings
    a little better. But there is a lot of content that I made. I could share
    it, if there was a place to put it all.
    Jay Ayala
    Mechanical Designer
    Portland, OR
    Distinguished Contributor
    04-11-2005 11:38 AM in reply to: bil-with-one-L
    Originally posted by: Roverto Zenteno
    Hello:
    Let me know.
    Roberto
    End Quote:
    Okay, if you are talking about the custom size Butterfly Vavle catalog, it's less then 1 meg.
    If you are talking about the other items, I would have to calculate that. Right now as it stands the first floor of my model alone is about 7 MB. But that includes a lot of piping, and HVAC that is pretty memory intenseive. If I had to guess I would say that those custom items I drew are probably about 2-4 MB.
    Email me if you are serrious:
    jay.ayala@hdrinc.com
    Jay Ayala
    Mechanical Designer
    HDR Architecture, Portland OR.
    *Roberto Zenteno
    04-14-2005 08:03 PM in reply to: bil-with-one-L
    The catallog is what I was referring to. The parts that you've developed. I
    could post them on my website for anybody to download. That is if you would
    like to share it.
    Thank you in advance.
    Roberto,
    wrote in message news:4811204@discussion.autodesk.com...
    > Hello:
    > library
    > Website.
    > Let me know.
    > Thanks,
    > Roberto
    > End Quote:
    > Jay Ayala
    > Mechanical Designer
    Valued Contributor rb
    Valued Contributor
    04-15-2005 07:34 AM in reply to: bil-with-one-L
    I would be interested in this also. I am just getting my feet wet with Building systems and find the lack of parts frustrating. I am going to a class to learn how better to develop the parts but it is waste if they are already out there.
    04-26-2005 12:44 PM in reply to: bil-with-one-L
    like to share it.
    Roberto,
    End of Quote
    Like I said, the library is less then 1Mb I think its 77kb + 150kb dwg file.
    Roberto, please email me and we can coordinate this off line.
    Jay Ayala
    HDR Architecture Inc.
    Portland, Oregon
