• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *Elrod, Kent
    Where are Express Tools?
    367 Views, 10 Replies
    06-04-2003 07:13 AM
    I don't find the express tools with the ABS2004 CD's, where can I get them.
    Kent Elrod
    Please use plain text.
    *Elrod, Kent
    Re: Where are Express Tools?
    06-04-2003 07:41 AM in reply to: *Elrod, Kent
    I looked at a vanilla 2004 install disk, the Express Tools are under Step 5,
    Install Supplemental Tools.
    In ABS2004 step 5, there is ONLY Hewlett-Packard DesignJet Printer Drivers.
    Autodesk, you forgot to put them on the ABS disk.
    I used a 30 day demo disk of plain 2004 to install the ET on my setup, so I
    am glad that that worked for me.
    Kent
    "Kent Elrod" wrote in message
    news:f16a8b8.-1@WebX.maYIadrTaRb...
    them.
    > Kent Elrod
    Re:
    06-04-2003 08:08 AM in reply to: *Elrod, Kent
    Is that my only choice for a fix?
    Al
    *Harper, Chip
    06-04-2003 09:12 AM in reply to: *Elrod, Kent
    This came up in the ADT group, perhaps the procedure is the same. Please let
    me know ...
    For installing Express Tools on ADT 2004: Using Windows Explorer,
    put the CD in, and turn off the install
    program if it launches (holding the control key down while putting in
    the cd should prevent "autorun"). Navigate in explorer to the
    Adt\Support\Express folder and run the setup file. The readme file
    explains this under Installation Issues.
    Chip Harper
    Member of the AutoDesk Discussion Forum Moderator Program
    *Elrod, Kent
    Re:
    06-04-2003 10:17 AM in reply to: *Elrod, Kent
    Chip
    Thanks, I did open the readme and search for express, but perhaps I missed
    it. I will look tomorrow.
    Why such a convoluted method for the verticals when it was so obvious for
    the vanilla?
    Kent
    "Chip Harper" wrote in message
    news:E4225B9309725CDAE55FF3B3376C80DB@in.WebX.maYIadrTaRb...
    let
    > me know ...
    > Chip Harper
    *[Autodesk], jason martin
    Re:
    06-04-2003 10:59 AM in reply to: *Elrod, Kent
    As Chip indicated this is covered in the readme.
    Many of the features of the express tools don't work as "expected" with ADT
    and ABS.
    Please read the readme file in the express tools folder of the ABS CD, as it
    covers many of the known issues regarding the express tools and ABS and ADT.
    jason
    news:2A8FDA3AA900FBA825571D0E13253E09@in.WebX.maYIadrTaRb...
    > Chip
    > the vanilla?
    > Kent
    *inc, chris yanchar - autodesk
    Re:
    06-04-2003 11:03 AM in reply to: *Elrod, Kent
    The main Buildings Systems readme should explain where you can install
    Express Tools from, and it will also call attention to a specific readme
    regarding compatibility issues you should be aware of when using Express
    Tools in an ADT/ABS environment. Due to several issues, we felt it would be
    a bit misleading to advertise them in such an upfront manner in the main
    front-end installer.
    Regards
    chris yanchar | product designer
    building solutions division
    autodesk, inc.
    > Chip
    > the vanilla?
    > Kent
    > let
    > > me know ...
    > > Chip Harper
    *Elrod, Kent
    Re:
    06-04-2003 11:59 PM in reply to: *Elrod, Kent
    Chris and Jason
    Ok, I found the instructions. From the Installation page > Documentation >
    Readme(.hlp) > Autodesk Arch. Desktop 2004 readme > Installation Issues.
    If you use the help topics > find > express, the information will be found
    for you also, again under the ADT readme.
    Since this is the ABS install I assumed the information I would need would
    be under ABS. I am new to the vertical products so I am in a steep learning
    curve.
    The documentation should, perhaps, reference ADT/ABS rather than just ADT
    when speaking of known issues. A small point I know.
    Kent
    "chris yanchar - autodesk inc" wrote in
    message news:ECCDD75E866135124C5F7EDFB04D0BE3@in.WebX.maYIadrTaRb...
    be
    > Regards
    > autodesk, inc.
    *Harper, Chip
    Re:
    06-05-2003 01:52 AM in reply to: *Elrod, Kent
    Just for my clarification ... was the path on the ABS CDROM,
    "Adt\Support\Express", the correct location or is it "ABS\Support\Express"?
    Chip Harper
    *Elrod, Kent
    Re:
    06-05-2003 02:05 AM in reply to: *Elrod, Kent
    Hi Chip
    The path on the CD is ABS\Support\Express.
    Kent
    news:836978AF7B922662663D3071A5C596F8@in.WebX.maYIadrTaRb...
    > Chip Harper
