• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD MEP
    Valued Contributor
    VIEWPORT TOOLBAR
    104 Views, 8 Replies
    08-26-2003 04:25 AM
    I HAVE THE MECHANICAL BUILDING SYSTEMS MENUES LOADED AND I AM TRYING TO GET INTO THE VIEWPORT TOOLBAR, OR INTO ANY OTHER BASIC AUTOCAD TOOLBARS?? AREN'T WE SUPPOSE TO BE ABLE TO USE AUTOCAD COMMANDS WITHIN THE BUILDING SERVICES PROGRAM??
    Please use plain text.
    *Andrew
    Re: VIEWPORT TOOLBAR
    08-26-2003 04:32 AM in reply to: tgarman
       You will either need to load the
    acad menu or a better solution would be to copy the portions of the acad menu
    you want into the building systems menu or a custom menu.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I
    PROGRAM??
    Valued Contributor
    Re:
    08-26-2003 04:38 AM in reply to: tgarman
    WHERE DO I FIND THE ACAD.MNU MENU??
    WHY THE EXTRA STEPS TO GET BASIC COMMANDS??
    *Yanchar, Chris
    Re:
    08-26-2003 04:41 AM in reply to: tgarman
    To scale a viewport, you can select the viewport and change in the
    Properties Palette. To create viewports that is automated with the Drawing
    Management feature...if you aren't using the Drawing Management feature then
    you can either go to the Views pulldown menu. With these methods being the
    primary workflow in ADT and ABS you no longer need the extra toolbar taking
    up space on your screen or need to toggle off/on.
    Hope that helps
    chris yanchar | product designer
    building solutions division
    autodesk, inc.
    Valued Contributor
    Re:
    08-26-2003 04:44 AM in reply to: tgarman
    YES THAT HELPS A LOT, THANKS
    *Bell, R. Robert
    Re:
    08-26-2003 05:15 AM in reply to: tgarman
    Just a quick comment... ALL CAPS IS CONSIDERED SHOUTING in the newsgroups.
    R. Robert Bell, MCSE
    www.AcadX.com
    "tgarman" wrote in message
    news:f1849c9.3@WebX.maYIadrTaRb...
    Distinguished Contributor
    Re:
    08-26-2003 06:26 AM in reply to: tgarman
    Oh, you'll have to excuse him, he just got back from oversees. He had a shell go off next to his head and now he's a little hard of hearing.
    *Bell, R. Robert
    Re:
    08-26-2003 06:28 AM in reply to: tgarman
    I thought he was just excited by the answer. ;-)
    www.AcadX.com
    "jmcfaddn" wrote in message
    news:f1849c9.5@WebX.maYIadrTaRb...
    Active Contributor
    10-03-2003 12:02 AM in reply to: tgarman
    you prob. found your answer by now... however, I just received the viewport toolbar via e-mail from one of my old co-workers. If you want it still I can e-mail it to you.
