• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Active Member
    Unconnected objects symbol
    226 Views, 4 Replies
    05-20-2009 06:27 AM
    Does anyone know how to turn off the unconnected objects symbol? This symbol is present when a duct or pipe is open ended. It ends up taking up the screen.
    Thanks!
    Please use plain text.
    Employee
    Re: Unconnected objects symbol
    05-20-2009 07:29 AM in reply to: justin.evans
    In 2009, on the View menu: Show Solution Tips, and Solution Tips Size.
    In 2010, there is similar functionality on the View Ribbon.
    Martin Schmid, P.E.
    Product Manager - Analysis and Countrification
    Architecture, Engineering, and Construction
    Autodesk, Inc.
    Active Member
    05-20-2009 07:33 AM in reply to: justin.evans
    Thank you! And in record timing too.
    05-20-2009 10:45 AM in reply to: justin.evans
    go to 'view' drop down menu
    click 'show solution tag'
    Member
    06-08-2009 08:50 AM in reply to: justin.evans
    Have you seen the unconnected symbol occur in vanilla AutoCAD 2010. If so, how do you turn it off!?
