• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    *Services, Tony - Autodesk Professional
    UPDATE - MAX and DRF file corruption caused by recent Microsoft Windows Updates
    58 Views, 0 Replies
    07-27-2003 10:53 PM
    FYI - As many of you are already
    aware, the scope of the MAX and DRF file corruption issue has expanded and now
    affects operating systems other than Windows 2000.  We are working to
    update our existing solution on this topic,
    href="http://support.autodesk.com/getdoc.asp?id=TS81105">TS81105
    , with the
    latest available information.  In the mean time, here is a draft of the
    revised content of this solution:
    Autodesk has confirmed that Microsoft Hotfix
    823980, which is contained in the Windows 2000 Service Pack 4, causes the
    corruption of MAX and DRF files resulting in the inability to open MAX or DRF
    files that were saved after either of these Microsoft Windows Updates had been
    installed.  The following Autodesk products are affected by this
    issue:
    Autodesk® Architectural Desktop 2004
    Autodesk® Building Systems
    2004
    Autodesk® VIZ 4
    3D Studio VIZ® R3i
    3D Studio VIZ®
    R3
    The following operating system configurations will experience
    MAX and DRF file corruption:
    Windows 2000
    Service Pack 3 or lower + Microsoft Hotfix 823980
    Windows XP Professional +
    Windows XP Home Edition + Microsoft Hotfix
    823980
    Windows NT 4.0 + Microsoft Hotfix 823980
    Autodesk is working with Microsoft  to
    identify a resolution for this issue.  Until a resolution is identified,
    Autodesk recommends the following temporary instructions to return affected
    systems to normal operation.
    Temporary Instructions for
    Microsoft Windows Hotfix 823980 Configurations
    If you have installed
    the Microsoft Windows Hotfix 823980, Autodesk recommends that you uninstall this
    Hotfix, which will allow existing or recently saved/corrupted MAX and DRF files
    to be opened without any errors.
    To determine if you have installed
    the Microsoft Windows Hotfix 823980, access your Add/Remove Programs dialog box
    from the Windows Control Panel.  If this Hotfix has been installed, there
    will be an entry with a title similar to "Windows Hotfix 823980".  To
    uninstall this Hotfix, select the "Windows Hotfix 823980" entry and click
    Remove.
    NOTE: It is highly recommended that you
    back-up any critical data before uninstalling Microsoft Windows Hotfix
    823980.
    IMPORTANT: In all cases, you should
    disable automatic windows updates through WinUpdate to eliminate the possibility
    of inadvertently reinstalling the Microsoft Windows Hotfix 823980 before the new
    Microsoft Windows Hotfix becomes
    available.
    Temporary Instructions for Windows
    2000 Service Pack 4 Configurations
    Method #1
    1. Uninstall the
    Windows 2000 Service Pack 4.
    2. Use the Merge command, located on the File
    menu, to retrieve data from the corrupted MAX or DRF files and then save the
    files.
    NOTE: If you have Render Effects or
    Atmospherics in your MAX or DRF file, use the Merge button in the respective
    dialog boxes.
    IMPORTANT: Some data may be lost
    if you use this method to work around this issue and Autodesk recommends that
    you retain original copies of any corrupted MAX or DRF files until a final
    resolution to this issue is identified.
    Method
    #2
    1. Uninstall the Windows 2000 Service Pack 4.
    2. Open the
    corrupted MAX or DRF files from a Windows XP system that does not have the
    Microsoft Windows Hotfix 823980 installed.
    3. Save the files and return the
    files to the system on which the Windows 2000 Service Pack 4 has been
    uninstalled.
    that you back-up any critical data before uninstalling the Windows 2000 Service
    Pack 4.
    As soon as a fix is
    available, we will update
    face=Arial color=#0000ff size=2> to include details on the final
    resolution.
    Tony Michniewicz
    Professional Services
    Please use plain text.
