AutoCAD MEP
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Text to MText
- Highlight
- Email to a Friend
- Report Inappropriate Content
Why is that while in AutoCAD MEP when I attempt to use the text to mtext command, it says the it is an unknown command? However, if I open the plain Autocad program, the command is recognized and works fine.
Re: Text to MText
- Highlight
- Email to a Friend
Which version of Autocad and Autocad MEP are you using? Prior to 2013 they were their own seperate programs but in 2013 they were combined to use the same files.
In either case the command is part of the express tool package and not part of regular autocad itself so you must make sure to install the express tools. In order to do this you must use the windows control panel and choose to uninstall a program. This will bring up the uninstall or change a program dialog. From here choose your version of Autocad MEP and then select the Uninstall/Change button at the top. This will start the setup program and from here you can tell Autocad MEP that you wish to install the Express Tools. The steps are the same no matter what version of MEP you are using.
Hope this helps.
Re: Text to MText
- Highlight
- Email to a Friend
Awesome, that did the trick! I had assumed the Express Tools had already been installed since the pulldown showed up in the MEP.
