- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a bit of a weird one here. I have Light Fixtures as devices and I have a Tag that displays the 'ID' as shown in the 'Design' tab of properties. After several hours of work my electrical engineers will experience a condition where the tags no longer refelect the changes made in Properties. If a new light fixture is placed after this condition occurs, then the tag displays the 'default' value that the tags block attribute default was set to.
Restarting CAD and reopening the drawing will cause all the tags to work correctly again. This tells me the drawing is not the issue, but the underlying code is getting broken somehow.
Has anyone else expereinced this? it seems to be only my electrical users, does anybody know if the code that runs the tag association is based on .NET or something else drawing data from a pool in Windows as opposed to its only memory space like the rest of AutoCAD? Might one of our (independent of CAD) lighting design software's be causing this crash in AutoCAD?
Any suggestions are appreciated.
AutoCAD MEP 2011 w/ all service packs
