• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD MEP
    Specifying Ductwork Settings 2010 to 2013
    176 Views, 1 Replies
    01-25-2013 03:01 AM
    Hi
    I am back on AutoCAD MEP after 3 years and the software has changed slightly. I have read that you now use the properties pallette to specify ductwork settings etc.
    How do I setup the software to only use square bends for Rectangular duct for example?
    I go to:
    >Properties Pallette
    >Rectangular
    >Properties
    In 'routing' i select bemd method as Elbow, but this is gemeric, how do i specify i want to only use 'DW144 Rect Duct Square Elbow Flanged' for example?
    On opening a new drawing with an aecb template i am prompted every time i try to turn at 90deg or branch off by the 'choose a part' dialogue every time, even though i select the checkbox 'make this part the default'
    Thanks for any input
    Please use plain text.
    Keith.Brown
    Re: Specifying Ductwork Settings 2010 to 2013
    01-28-2013 07:19 AM in reply to: lsop1409
    Use the command DUCTPREFDEF to bring up the style manager and duct routing preferences.  From here you can select the routing preference and then set the elbow to which ever elbow you want.  When routing duct, you then choose the correct routing preference from the property palette.
    Keith Brown AutoCAD MEP BLOG | RSS Feed
